I've tensile tested several Nicopress cable assemblies. In all cases, the cables broke, leaving the crimps and eyes intact.
This is an interesting post on several levels.
1) it deals with eyes , not stops.
2) It begs the question, "Where exactly did these cables break?
You know as well as I do, that a terminal stronger than the cable will break at random positions when over-stressed.
I suspect, without knowing for sure, that the wire breaks would be close to the terminal - a feature of any abrupt cross section change; but I would expect this failure mode to be exaggerated in the rotary swage terminal, where the cable compression begins at the very end of the terminal and continue with the cable extension associated with the barrel extrusion towards its end; less so with the roll swage which begins at the end and extrudes barrel, allowing the cable to retreat to the cable side.
In this regard, the Nicopress seems to offer advantages; the swage is localised and allows cable relaxation IF the first squeeze is central and the subsequent squeezes trap the ends (possibly?) but some lateral movement of the terminal meets a soft barrier rather than the hardened steel collar at the wire side of the cable.
But this has its limits:
The Loehle wheel suspension comprises two telescoping tubes with lateral bolts upon which bungee cord is tight-wrapped. Over-extension is stopped with a short restraining cable mounted internally. Simple, and quite effective. This puts two eyes swaged with Nicopress fittings into varying bending loads, Fatigue failure of the wire is inevitable at the swage, sooner or later.
A terminal much used in sailboats is the screwed compression chuck and cone end insert.
It looks like a roller or rotary swage, but is apparently more chancy.
I expect there are more methods - such as the 'hot pour' approach, which fills the interior of a terminal with an end-cone full of lead alloy for instance.
And so I suppose I should end with the Eddystone lighthouse. This was perched on sea-washed rocks and tended to depart in high heavy seas. Until that happy day, when anchor-bolt holes were drilled into the rock, and studs were placed after pouring the hole with hot wax, and setting them with molten lead. These fittings held up against the worst of 50 foot waves in storm surges for many years.
Brian W
