Suzuki SV650 Engine
Discussion in 'General Auto Conversion Discussion' started by 1684zach, Feb 8, 2011.
  1. Feb 8, 2011 #1
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    I am thinking about using a Suzuki SV650 engine on the plane I am currently building. They have a very solid reputation for reliability; and after a lot of research with my brother (a motorcycle guru), I think it has the best reputation, weight, HP, liquid cooled and '03 and after are all fuel injected. I will lock it in the gear I calculate to give the best prop RPM and strip the rest of the gears to save more weight. Any one have thoughts or concerns I might have overlooked-? I have spent the last few years asking lots of questions and doing a tremendous amount of research on this subject. If this works, I may use the big brother of the SV650, the SV1000 and mount it on my next project- CH750
    -Zach
  2. Feb 8, 2011 #2
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,544
    Rotterdam, Netherlands
    Torsional vibration. (between prop, engine and gear)
  3. Feb 8, 2011 #3
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    I am planning to make a dampener to go between the prop hub and the transmission. I have used this on a much smaller scale in the paramotors I have built using small four cycle engines.
  4. Feb 8, 2011 #4
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,741
    1,001
    Warren, VT USA
    The Jetski version of this engine has a rubber damper and cast metal hub. I would bet the tapered output shaft is the same. You could use those parts to get a rubber output damper. I am looking at the jetski engine as is or with the newer electronic fuel and oil injection added on for my direct drive concept.
  5. Feb 9, 2011 #5
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    Can you put up a link to something that shows the engine-? I can't find, and had no idea that there was a jet ski version! But that sounds like what I need, with minimal effort involved.
  6. Feb 9, 2011 #6
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,741
    1,001
    Warren, VT USA
    Kawasaki 650 SX TS SC X2 JM Motor Engine Jetski Jet Ski - eBay (item 270627561214 end time Feb-23-11 07:19:55 PST)
    KAWASAKI JETSKI JS 650SX 650 DRIVESHAFT DRIVE SHAFT -93 - eBay (item 190316006100 end time Feb-10-11 17:57:11 PST)
    Kawasaki 750/800 Jet Ski Rubber Drive Shaft Damper - eBay (item 320604934162 end time Feb-14-11 15:46:55 PST)
    I gotta be a dope to give away my secrets! :)
    The Jetski setup including exhaust, coupler, and driveshaft (modified to hold prop flange an thrust/radial bearing/housing all combine to make a nice direct drive. I would look at snowmobile final drives for off the shelf parts for a belt drive reduction unit. Same basic motor. These are all already made to fit in tight spaces and to be water cooled.
  7. Feb 9, 2011 #7
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,542
    3,385
    Mojave, Ca
    Am I missing something, or does the fact that one engine is a Suzuki (SV 650) and the other a Kawi (650 SX) make a difference to the final drive?
  8. Feb 9, 2011 #8
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,741
    1,001
    Warren, VT USA
    I have been looking at Jet Ski plants. Substitute Tigershark PWC 650 for Suzuki same, same.
  9. Feb 9, 2011 #9
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    I actually have the Kawasaki 650 engine. The problem is, it is two stroke and on the heavy end of what I need. I like the Suzuki because it is four cycle, VERY reliable cheap to buy, cheap to maintain, light, and it has my "psru" built in already.
  10. Feb 9, 2011 #10
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    I actually just stumbled over this in a separate thread:
    Nouvelle page 1
    I have been searching for several years to see if I would be the first to use this engine, but it looks like this guy beat me to it. Now, if only I spoke Bulgarian.
  11. Feb 9, 2011 #11
    Richard6
    Richard6
    Richard6
    Aug 14, 2010
    681
    77
    Plymouth, MN USA
    I would be concerned about heat build up in the chain.
    Richard
  12. Feb 9, 2011 #12
    1684zach
    1684zach
    1684zach
    Feb 3, 2011
    15
    0
    Bellflower, MO.
    I don't think I will use a chain. I was thinking more of coming straight out of the transmission with a torsional dampener, then the prop hub. I just posted that link to show the exact engine I was thinking of using, and that someone has already beat me to the punch.
  13. Feb 9, 2011 #13
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,542
    3,385
    Mojave, Ca
    Ahhh... The "generic" use of the term "jet ski" (aka PWC).
    Got it.
