It seems to me that the limitation on a VW is the exhaust valve; you need to take good care of the exhaust valve. It only cools when it is closed, and the heat flows through the valve face into the seat then into the head. Keep your expectations modest and there are some performance gains to be had - but only at high altitude. If you like to fly cross country above 8,000 feet, or it your airport is above 5,000 feet, then the supercharger (and fuel injection) makes sense. For most of us, a set of 94 mm cylinders and perhaps an 82 mm crank will be sufficient. The normally aspirated engine will lose power at the rate of about 3% per thousand feet, so there's a crossover up there somewhere.
