Super Cub with Kubota wind driven genny
Discussion in 'Instruments / Avionics / Electrical System' started by Twodeaddogs, Jun 22, 2017.
  1. Jun 22, 2017 #1
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    Hi all,
    I'm trying to track down a wind driven generator installation, which I have seen fitted to a Super Cub, in a video. It consists of a Kubota gene or dynamo driven by what appears to be a marine type propeller, which appears to be a multi-bladed type, possibly from a trolling motor,made of either red plastic or red-painted metal and the whole assembly is fitted between the undercarriage legs. If anyone has a clue about this unit, let me know.
    regards
    TDD
  2. Jun 22, 2017 #2
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,274
    520
  3. Jun 22, 2017 #3
    6,886
    2,522
  4. Jun 22, 2017 #4
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,274
    520
    I made a homemade version for my old Team Airbike. I used a Kubota dynamo and a homemade prop hub with a model airplane propeller. The dynamo puts out AC power so you will need a regulator/rectifier. I used a Key West unit: http://www.aircraftspruce.com/catalog/eppages/keywestregulator.php It worked well to keep my small lead acid battery charged.
  5. Jun 22, 2017 #5
    Sep 18, 2008
    5,028
    2,195
    I made one for my Jodel using a small, ball-bearing 12VDC motor from a photocopier. The propeller I made first from wood, then steel, and was only about three inches across. The pitching and airfoil of a wind-driven prop is some different from a driving propeller like a model prop. This thing generated 1.5 amps, enough to keep the small lead-acid battery charged to run the radio. However, it made a lot of RF noise that I couldn't get filtered out; no amount of chokes and capacitors would stop it. I think it was being radiated off that steel prop, which picked it up off the armature shaft. I removed it and just charge the battery occasionally.
  6. Jun 22, 2017 #6
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    Thanks for all the help but it's not quite the one I'm looking for. The subject aircraft is a Super Cub on big fat tyres, which has a red propellor on the front of the Kubota. For the life of me, I can't remember where I found it. My friends who have used gennipods and other makes found them unsatisfactory.
    regards
    TDD
    I can't upload the video as it is an mp4 and the computer tells me it's an invalid file!
  7. Jun 22, 2017 #7
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    ...just a thought
    Something like the prop/spinner on the Gennipod II would be a simple thing to print out of Nylon and would cost about 50 cents.
  8. Jun 23, 2017 #8
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    By chance, I found a prop on the internet that appears to be the same as the one in the video; a Vetus bow thruster propellor, about 185mm diameter, which appears to have been installed backwards to the airflow from the aircraft propellor.
  9. Jun 23, 2017 #9
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    Found it; turned out to be a Vetus bow thruster propeller, driving a Kubota dynamo under an Experimental PA-11, by a chap called Peter Brown on Facebook.
  10. Jun 23, 2017 #10
    Mcmark
    Mcmark
    Mcmark
    Sep 24, 2013
    291
    148
    Owings, MD
    Would you post a link please?
    Trying to solve power issues for my Cubby.
    Thanks
  11. Jun 29, 2019 #11
    103
    103
    103
    May 3, 2015
    172
    99
    Wauwatosa WI
    Look at FARMBOY Dialog on link below.
    https://www.supercub.org/forum/showthread.php?48723-Solar-Chargers/page4
    Source for red fan
    https://www.anchorexpress.com/Prope...2q0TXKT7UxwoWOY17hfonFlmO7zZHShhoC-gQQAvD_BwE
    Also here is a nice exploded diagram of the Dynamo.
    https://www.tractorbynet.com/forums.../172004d1279728986-dynamo-bearing-bearing-gif
    REF Good pictures of the Kuboto insides replacing the bearings.
    https://www.mytractorforum.com/54-k...00-alternator-dynamo-bearing-replacement.html
    Dana likes this.
