Substitute phenolic with delrin?
Steveastrouk
Jul 22, 2021
In the canard wingroots and other places, we're running with IGUS Iglidur plastic bearings. Iglidur is available as stock bearings and plastic raw material. Its also availaible as 3d print filament.
6,373
In that application. I think Delrin would be just fine. I have a bunch of small pieces here that are getting smaller all the time as I make stuff. I recently fixed up a 1963 Johnson 10-horse outboard as a trolling motor for my boat, and had to do a bunch of repairs to the gearcase. The seals had been leaking so some crazy dude had stuffed it full or grease instead of the gear oil. The bottom end in that thing is all bushings, C93200 bronze and hardened steel. I could not find bronze at any machine shop anymore; seems that nobody makes such things anymore. In the 1980s I bought a lot of C93200 to make numerous types of bushings and bearings, hundreds of each part number. Fiddlesticks.
So I machined a new driveshaft bearing and a new propshaft thrust/forward bearing from Delrin and put them in, replaced the leaking seals, and filled the case with gear oil. Going fishing next week and those bearings will get a workout. I'll pull the case apart this winter and see how they did.
One of the compressor types we overhauled in the '80s used Delrin wrist pin bushings in the con rod. Those compressors that were naturally aspirated did fine with it, but the ones that had their intakes plumbed to the turbocharged engine intake did not. They wore out quickly, since the constant pressure on the piston prevented any oil entry to the pressure interface between the pin and bushing. We replaced them with C93200. It wasn't so much a wear issue; it was the deformation caused by the constant pressure and heat. Turbocharging compressors was the standard way of stopping oil pumping; when a compressor is unloaded, its intake valves are open and the air is just pumped back and forth between the two cylinders instead of being forced out the discharge valves and into the system. With no cylinder pressure, and little heat from compression, the piston would contract and start moving sideways a bit in the cylinder, pulling the rings off just enough to let oil past them, and that oil would accumulate on top of the pistons and get blown into the system when the compressor went back to work. Gummed everything up, and made a lot of carbon coking in the compressor head. Turboing it fixed that.
I'd use the Delrin for the rudder bar blocks and put a bar of steel or aluminum across the top, under the bolt heads. If the bearing fails the bar can't get away; it would just slop around some.
These are Cessna rudder bar bearing blocks. They're plastic and have been for 50 years, at least. Don't know what type, but nylon would be my guess. Maybe they're Delrin now. If a plastic block is good enough for a 185, I think it's good enough for a homebuilt. I never found one of these broken but I did find the light aluminum fuselage rib flanges they were bolted to cracked and broken. No metal plate over top, either.
SamP
Nov 4, 2016
53
Thanks for the thoughts. It’s for a rudder pedal mount on a sonex.
I saw on the rv-12 the other day that it has delrin as the moun instead of phenolic, so that’s double reassuring
pehnolic doesn’t seem to be particularly good as a bearing surface. It feels pretty abrasive and leaves powdery residue everywhere!
6,373
Phenolic is urea-formaldehyde resin with a linen fabric reinforcement. Not only ancient technology, but that dust is also dangerous. You don't want to breathe it.
10,212
In my day job (designing automated machinery) I use Igus "J" bearings a lot.
karmarepair
Jan 13, 2011
672
United States
I'm with Dana, Delrin is an excellent bearing material, I often use it for bushings.
Even better, but I have NO IDEA where you can find it in "retail" quantities, is "Thordon". It comes in several grades, and in the marine trades it's driven out phenolic in anything greased or water lubricated or "dry running".
10,212
There are various grades and brand names for the different types. "Garolite" and "Yorolite" are two. The reinforcement can be paper, linen fabric, or fiberglass, and the binding resin may be urea-formaldehyde, rubber, epoxy, and no doubt others, all with different combinations of strength, temperature resistance, etc.
trimtab
Apr 30, 2014
276
rocky mountains, rocky, usa
A 10% to 15% filled nylon 6 with moly is stronger and slipperier than most micarta grades and will cost about 25 bucks for enough material to make the blocks plus an extra.
If it were me, though, and it is not, I'd go with the IGUS suggestion given above and make the blocks out of whatever you find that is perhaps stronger than UHMW. Why? If it wears, the IGUS bearings are cheap and easy to replace...no fab required.
Lendo
Feb 6, 2013
869
Brisbane
Dana, Yep! I've used oil impregnated Delrin in products and would be fine in this application. Much better than a bolt (into tube end) through a end bracket, like in some aircraft, but that does the job well enough for some designs.
George
speedracer
Feb 4, 2020
209
Not sure if this is the best subforum, but here it goes!
I have a rudder pedal mount that I need to fabricate. The rudder pedal rotates between two peices bolted together. Plans call for fabricating it our of phenolic, but I want to use delrin instead because:
  1. I have some lying around
  2. Aircraft spruce is charging me 60 bucks for shipping of a phenolic sheet
  3. I think the movement will be smoother with a delrin mount
Would there be any concerns for this substitution? Thanks!
[/QUOTE]
I installed the IGUS wing/aileron root bearings in my LongEZ, EZ to install and smooth as butter. In my previous LongEZ the plans phenolic bearings were worn out at 500 hours. I made new Delrin bearings and 1,000 hours later when I sold it they hadn't worn a noticeable bit.
Winginitt
Apr 5, 2019
197
Perhaps a sketch or copy of the blueprint detail would provide a better idea of what you are trying to do. Not sure if you want the stuff for making a bracket or a bushing........
Winginitt
Apr 5, 2019
197
Scrolled thru this again and saw that Clutonfred had posted a dwg. Since reliability is paramount with your controls, Using anything that can flex or crack easily is not the best choice. On the drawing above it also shows aluminum as being a viable choice. Aluminum is much less likely to fail than the other choices. I would look up "bunting" bushings on Ebay, and purchase the correct size ready made bushings and machine the aluminum blocks for a press fit. Much more rugged than the other choices and easy to make. It would be 1 piece instead of two.
