Subjective crankshaft vibration
rmeyers
Dec 20, 2013
35
Denver, CO
Here's a question for you guys with a lot of VW experience. How much difference is there in the apparent smoothness between a counterweighted and un-counterweighted crankshaft? What effect does displacement, bore and/or stroke, have?
Grumpy Cynic
7,717
None - presuming that both are correctly balanced. The counterweights are used for structural reasons.
Saw a 4 cylinder boxer in half, like a half VW or the O-100, and they then can make a noticeable difference in engine shake.
Stroke is probably going to effect the 2 cylinder shake more than bore.
Displacement is related to the power pulse magnitude.
9,136
Haven't used a counterweighted crank with a prop. But, as Hot Wings said, if correctly balanced the un-counterweighted crank is very smooth. On the SSSC with a balance stock VW 69 mm crank, etc, and the same CR with each cylinder, its almost electric motor smooth with a balanced prop. That means more power and longer life.
rmeyers
Dec 20, 2013
35
Denver, CO
At our direct drive RPMs there should be no difference between counterweighted and un-counterweighted. Nice to see you guys real world experiences backs up the theory. Thanks.
Next question then; where does one find an un-counterweighted 84 mm stroke crank? All of the strokers that I have been able to find have counterweights. I have multi-axis CNC capability and could cut the weights off but it would be nice to find an affordable crank than didn't have counterweights.
Grumpy Cynic
7,717
Other than weight savings there is no reason not to use counterweights. They may not make a noticeable difference in engine vibration, but they DO serve a very useful purpose.
Without going into a lot of detail ......... they make the engine last longer. As RPM, stroke and reciprocating weight increase counterweights become more important.
5,107
not very up on VW....so as long as we are here I can learn something.....when you say counter-weight....is that a pivoting weight like on the counterweight aircraft engines or is it just a larger lobe on the bottom of the crank opposite the rod?....In either case I would assume the idea is to balance the weight of the piston and rod and do not see how cutting it off would be a good thing.
5,107
big half circle(ish) slab opposite the rod journal.
welded.....I guess there are no stock engines of that size?.....I can not imagine VW would do that....but I really do not know.
Grumpy Cynic
7,717
I picked a welded one because it is just one option for homebuilders - especially 1/2 VWs.
Normal aftermarket cranks have the counterweights forged as an integral part of the crank. Most aftermarket cranks seem to be kind of skimpy on the counterweights. This works out OK on the 4 cylinder versions.
The 1/2 VWs need all the weight they can get - even to the point of drilling the opposing rod journal to reduce the weight on that side of the crank. Same reason Pete had a custom crank made and used light weight rods and pistons for the O-100.
14,692
It’s part of the casting/forging of most car engines unless you are talking MGs and Triumphs or some other tractor engines car. The moving weights on airplane engines are a different harmonic fix. They are not on every journal and act like a harmonic balancer not an overall balance.
Richard Roller
Feb 15, 2018
57
Olathe, Ks.
No pendulum weights on a VW crank, just a big half circle(ish) slab opposite the rod journal.
Some people attach counterweights to the Ford model A crank used in the Pietenpols. In the case of N34KP the weights are attached with cap screws and welds on the ends.
9,136
I built one 1/2 VW and welded counter weights on the crank that Hummel engines sells for the job. Very hard to do. Had to use a very small cup using Tig and a hard job, I would not build another. For all the machine work, Scott's prices at Hummel are a good buy for the crank or a complete engine.
