STOL 50kg payload aerofoil design
RPM314
Mar 27, 2015
724
NY, USA
Well you need to know more about the plane to design a foil specifically for it. Otherwise you can search for foils typical of STOL aircraft. The UICI database is one good resource for that.
13,085
50 kg is not hard with no other restraints; more data is needed otherwise put it in the back of a cessna. 50kg with a 1 meter wingspan would be a challenge. Is this for a school project or commercial project? Is it one lump or can it be spread out? All that stuff matters.
Norman
Nov 28, 2003
2,974
Grand Junction, Colorado
Is there a size limit? The highest lift at a given speed is achieved with multi element airfoils. Google for "CH 710" to see an example. There are NACA documents in PDF format showing how to design them.
RPM314
Mar 27, 2015
724
NY, USA
...but if you go overboard on that you sacrifice performance in other areas. Point is, you need a clear definition of your plane's mission.
