Steps to scratch build a VW
103
May 2, 2015
374
Wauwatosa WI
Dealing with any flat tappet era engines and vehicles all run flat tappet pre Cat era plus Cat era street legal Calif. vehicles. Adding Comp Cam's Break In Oil Additive at every oil change long before the EPA started slowly reducing zinc and phosphorus in oils. High concentrations of zinc and phosphorus protection era long gone but not the engines. With roller lifter equipped modern engines they can operate without these additives, EPA pushed that bill.
Synthetic about the only advantage I see is it can stand slightly higher temps before breaking down turning into carbon, best used in race engines pushing oil temps to the extreme temp limits already. I also add zinc and phosphorus additives to synthetic oils used in flat tappet engines. Engines requiring leaded gasoline now running on unleaded another engine's slow death exhaust valve seat and valve face disaster, another different topic altogether. Union 76 110 octane leaded gas mixed with unleaded in the 60's & 70's era motorcycles. Redline Lead Substitute additive to unleaded gas out on the road and return trips home. Old leaded valve seat and valve engines maintaining solid valve clearances no recessions. Cams and lifters also not showing any scuffing or wear marks at all on hard working high temp air cooled bike engines. My 2 cents.......~~=o&o>.......
Yes and that is the reason the mineral oil T4 by shell is a solid choice. William is monitoring the supply for new shifts and if adding 1/2 bottle to every change you have a measure of protection should shell drop what we need. I think the VR1 is excluded from the policies and will remain viable ine can only hope
103
May 2, 2015
374
Wauwatosa WI
Hey "103" Valvoline VR1 has great engine oil protection, great for short run engines like drag racing but used on the street gathering miles your gonna end up with a sludge monster really quickly. Ugly buildup within 10,000 miles what I saw on a factory new engine after break in starting with dark a light turning to brown coffee stain looking internals, later mileage sludge starting to build up.
Even diesel's Delo 400 the good additives have been removed with people still thinking they are protecting their engines when they are not.....~~=o&o>......
I keep my oil change interval short at 25 hours. Looks like clear honey until hour 20 and begins to darken but no sludge at 25 hours burning 100LL all the time about 2.5-3.5 gallons per hour depending on mission at hand.
9,008
Don't forget the .040 orifice built into the plug that supplies oil to the #4 main bearing ( pulley end ). When using a flywheel drive aero engine, are you going to drill it out or leave it in ?
With the extra oil to #4 bearing, when you drill the orifice out, there seems to be a little more chance of oil getting past the crankshaft oil slinger . So it seems to require a better low pressure in the crank case to stay dry around the prop hub when using the prop on that end.
Has anyone tried an after market SAND SEAL pulley instead of the stock VW pulley for the flywheel drive engine ?
https://www.cbperformance.com/product-p/1899.htm
9,008
All the same for me. I try to burn 50/50 auto fuel and 100 LL most of the time.
dmar836
Jun 16, 2014
98
KC
I think the .040 orifice is a good discussion. I have often wondered about the "reversed" thrust loads on the #1 bearing with a flywheel drive conversion and it's effects.
Dave
karmarepair
Jan 13, 2011
355
United States
IF you install a sand seal, you'll need a new INLET for the crankcase, and the valve covers were the usual place to put a FILTERED inlet. https://www.jbugs.com/product/9164.html?utm_content=shopping&gclid=Cj0KCQjw2K3rBRDiARIsAOFSW_64LmyKLLheK9uxq74SAl-MttKlt9mlPL_cg7-z_353uU6mOqsEggoaAio5EALw_wcB is the easy way to put a nostril in the valve covers, although this listing makes it seem like the seller thinks this is an OUTLET for crankcase emissions. Veeduber talks about this https://bobhooversblog.blogspot.com/2007/07/crankcase-ventilation.html and https://bobhooversblog.blogspot.com/2007/02/blow-by.html (one of his more long-winded pieces)
karmarepair
Jan 13, 2011
355
United States
Dave
The thrust bearing inside the engine needs to be set up differently when the engine is assembled.
Every VW engine coupled to a manual transmission has to have the crank resist the thrust loads placed upon it by the clutch disk. This is USUALLY set between the main bearing and the flywheel with 3 shims, chosen to get the right clearance. This method works fine for Fan End hub Tractor applications, the usual practice for flying VWs. On a flywheel drive tractor application, the shims go INSIDE the case, with the INSIDE of the main bearing becoming the thrust face, reacting against the last crankshaft throw. The shim need their ID opened up a little to accommodate the fillet that SHOULD be there on the main bearing journal. I'm not sure if Bob ever posted this stuff to his blog, but attached are a few sketches.
9,008
Flywheel drive VW engines were used in homebuilts in Europe in the 1950's. In 1960 I was thinking of starting to build a Jodel D-9. But got so discouraged about flying after having to start wearing glasses and had to forget my dreams of flying for the military or the airlines. I even decided to not build the D-9 and wouldn't go to an airport for about 9 years after being an airport bum since the end of WW-2.
Latter I did finish a Falconar F-12 in 1979.
http://users.lmi.net/~ryoung/Sonerai/Hugh_History.html
karmarepair
Jan 13, 2011
355
United States
Ha! That's my old web site.
I think Bob Hoover (Veeduber) flew an Aeronca C-2 (C-3?) converted to use a VW engine (one of the ones <"36 HP"> with the cast-in generator towers - Bob got the engine for free from a local dealer when one of the early imports got rear-ended, and snapped the tower off the case) as early as 1955. The Jodel D.9 first flew in 1948, but I can't find when the first D.92, with a VW engine, first flew, but it had to be the early 1950's.
9,008
Small world. Hadn't thought about the Moon Maid in a long time.
dmar836
Jun 16, 2014
98
KC
Karmarepair, thanks for the info. So the pulling force of the tractor setup rides on the shims?
Dave
Grumpy Cynic
7,633
Dave
In the stock set up the shims are on the flywheel side. given that there is only .003" end play I doubt it makes much difference what side the shims are on with regard to thrust. .003" divided up between 4 surfaces doesn't leave a lot of room for an oil film between the shims.
I'd just turn the main bearing around* (move the dowel pin hole) and leave the shims on the outboard position - where they are easy to work with when setting the end play.
* if the case thrust surface has been cut then this isn't an option. If this is the case then notching the back side of the bearing is the only option to make sure there is oil at the actual thrust surface.
9,008
When I built a cut case 1/2 VW I used a #1 bearing with the thrust surfaces in place of the #3 bearing. Enlarged the ID of the shims at the rear of the bearing and installed shims in front of the bearing. Had to turn down the rear face of the cam gear on the crankshaft to make room for the shims on the front side of the cam gear on the crankshaft. Also had to turn down the rear face of the large cam gear on the cam the same amount. The engine could be used at a tractor or pusher.
Grumpy Cynic
7,633
Same way I did my 1/2 VW - except I don't remember having to enlarge the ID of the thrust shims. Been a long time ago. I do remember cutting the gears.
9,008
Yes, have to enlarge the ID of the thrust shims a little due to the radius of the crankshaft. As in post #507.
dmar836
Jun 16, 2014
98
KC
It does seem strange to have the shims in thrust especially if they are not fixed and are “floating” about the radius of the #1 crank journal.
Dave
blane.c
Jun 27, 2015
4,576
capital district NY
So the shims slide down the crank journal?
Annotation 2019-09-02 221250.png Are these commonly available? They are not likely to be thick, a few thousands?
When you slide the crank "endo" in the case the big end of the rods have enough play and it doesn't matter if there is more clearance on one side of the rod than the other in the throw?
9,008
When using a shrunk fit or tapered prop hub on the pulley end of the engine , you also use a seal installed with JB Weld. ( VW Bus Rear wheel Seal ). IF you do not vent the crankcase in a low pressure area ( I do it how VW does it). I run the crankcase vent tube to the inlet of the carb, you will still have a little oil leak around the oil seal at the prop hub when nose down when you approach to land and at idle rpm.
Blue hose in front of carb inlet in picture.
Charles_says
May 26, 2019
137
I don't know if you get it in the US, but we use Penrite in older design competition engines - they have a "full zinc" range.
I use the Valvoline VR1
20W-50 in the summer I get it from my local Ag Store for $2.50/quart. IN the Winter I use SHell Rotella T4 10w-30 from the same ag store or many others for $13/gallon. The ZDDP content is high enough for flat tappet engines that have been broken in.
William's Oil Change Video speaks to goo practices and the advantage of ZDDP in flat tappet engines.
I've been using Shell Rotella T5 15W-40 in all my 4 stroke engines since about 2005. Wouldn't use anything else. (YMMV)
Building a Corvair engine for flight use, I followed WW's guidelines.
"ZDDP" is available at Eastwood.com Under 8 bucks.
https://www.eastwood.com/ew-zddp-oil-additive-4-oz.html
dmar836
Jun 16, 2014
98
KC
Blane, In a car or pulley drive conversion the shims go on the flywheel end of the crank after it is installed and the case closed up. One must install shims and then the flywheel and torque it down with the “big nut”. This sets the end play of the crank. Measure fore/aft play with a dial indicator. This may take several attempts to get the right combo of shims.
Not sure if your rod question is a separate one?
Dave
