SpreadSheet Questions
JerryFlyGuy
Sep 7, 2005
67
Canada
Ok a bit off the topic but I use Excel for alot of my calculations. I've been working on a couple more complex formulas which need to be plugged into a second formula to get the proper values. There are two final variables. Anyone good w/ spread sheets that can help me?
JerryFlyGuy
HeliDev
Jul 7, 2003
108
Theres a program addon for excell called solver. That will solve for 2 variables.
You should be able to find it with a search.
8,477
Solver can be used or there are formulaeic methods using Excel with the iteration turned on... Tools>Options>Calculation> then turn on Iteration.
I did stability and control with Excel. More tonight.
