SportAir TIG Workshop, September 16-17, 2017 @OSH
Chris In Marshfield
Jan 29, 2008
1,262
Germantown, WI USA
Hi all,
If you're local(ish), there's a SA TIG workshop being held in Oshkosh 9/16-17. If you've seen the EAA TIG Video and watch TIG Time on YouTube, you'll recognize Mr. TIG as the instructor of the class.
Maybe I'll see a couple of you there. :)
~Chris
Little Scrapper
Jan 3, 2014
5,674
Wisconsin
Have fun, Chris. Education and practice is what it takes. I'm sure a follow up post of your experience would be beneficial for many people who click on this thread one day.
Chris In Marshfield
Jan 29, 2008
1,262
Germantown, WI USA
The September class fill up quickly and I got put on a waiting list. The next class is this weekend, and I was able to secure a position. Looking forward to learning from Mr. TIG himself, Wyatt Swaim!
Chris In Marshfield
Jan 29, 2008
1,262
Germantown, WI USA
Below is a collection of posts that I made over the weekend related to the workshop. I'll consolidate them here. Might take a minute to get the photos linked up.
Chris In Marshfield
Jan 29, 2008
1,262
Germantown, WI USA
Completed the first day of the EAA SportAir Workshop for TIG welding. A fella learns a lot about himself when stuck behind a darkened mask for eight hours. This course had previously been taught at Lincoln Electric in Griffin, GA, but has been moved to Oshkosh.
Taught by Mr TIG himself, Wyatt Swaim, a wealth of information was distributed by the man who is probably the leading expert on the technology. Best thing is that he’s approachable, loves to tell stories about his own welding experiences, and a joy to be around. If you’ve watched the EAA TIG Welding video, or watched TIG Time on YouTube, that’s the guy.
We did the usual stuff, like creating tacks, doing weld runs, etc. Then lap welds, butt welds, T joints, and the other routines that humble you in a hurry. Then had some fun with tubing.
They plan to create an advanced class that centers more around fabrication, as this course is meant to cover the basics. That should be fun when it comes about. But I just took matters into my own hands toward the end of the day as I simulated a strap hinge and did some other fun things that I’d learned from Earl Luce during gas welding workshops.
Saturday was mild steel and chromoly tubing. Sunday will be aluminum and stainless.
I can see why folks are fans of building with this technique. The amount of control is pretty spectacular. Now I just have to figure out the right combination of shade darkness and reading glass magnification to see well.
Chris In Marshfield
Jan 29, 2008
1,262
Germantown, WI USA
As closing comments for this weekend's workshop, I'm pretty sure that I am, indeed, addicted. I first touched a TIG at AirVenture a couple of years ago. Shortly afterward, I went over to the Lincoln tent and bought the Square Wave 200 (same unit we used at the workshop and in class this weekend). I really wanted to go to Georgia to take the 2-day TIG workshop held at Lincoln. I was very pleasantly surprised when I found out they moved it to Oshkosh. I had signed up for September, but it was overbooked, and they had another one this past weekend. They're having a third in a few weeks. So it must have been a success.
I was really looking forward to aluminum welding. The 120Hz that I scratched into the surface in one of the images above was so I could take a look at the difference between a 60Hz weld and a 120Hz weld. For the uninitiated, the Lincoln 200 is an inverter machine, which means a computer manages the output (gross oversimplification). It also means that when welding aluminum with AC, you can adjust the frequency of the energy used for welding, in addition to the balance of the waveform (more or less positive versus negative portion of the AC energy). Anyway, I found I like 120Hz early on because the cleaning action seemed to be more aggressive (higher frequency, cleaned more often), allowing me to move at a more comfortable speed. But I need more practice to find the sweet spot for me.
When I finished that aluminum weld, I cleaned it off with a stainless brush, and I saw an interesting edge formation that a fellow Bearhawk builder noted. He mentioned that it was a result of the unique heat characteristics of aluminum, and that my weld probably needed to be a bit hotter. He noted (paraphrased) that in the middle of the bead one can see the area where the lateral edge of the puddle meets the work, and that there is a broken edge look to it. If compared that same area but on the right end, there is no saw-blade look there. They call that the "toe" of the weld. If you see it looking like a saw blade you need a bit more heat. That pattern is a sign that the edge didn't intermingle with the base completely. Aluminum is such a heat sucker its easy to get too cool. I realize that this was an intro class and we probably weren't going to get far into the chemistry and what-not of welds and some of the finesse options. I'm sure the goal of this weekend was just to make sure we could get two pieces of metal to stick together. I appreciated my building colleague's description of the nuances of these kinds of welds. It will certainly help me become a better welder as time goes on. We also received a book from Lincoln specifically about welding aluminum. I'll have to give it a look and see if it points out some of the same.
The stainless welded with a small puddle, very slow, but clean. The tiny pieces we were welding heated up pretty quickly, so you could get booking in a hurry, and would have to back off on the foot pedal to reduce the amperage and slow things down a bit. But I do like the way it welds.
Welding plate was fairly straightforward. It wasn't too difficult all said, although it did take some practice to figure out how to aim the heat in various joint configurations. Tubing joints were another thing altogether. I chased a lot of holes over the weekend. I'm quite sure I completely destroyed the metallurgy attempting to "fix" things (if that's possible). But **** it all if I was going to let a hole stare me in the face! When I have some more time, I'm going to have to work the heck out of some tubing joints, and practice with different current selections. The problem with this particular class is we didn't have anything much in the way of tooling or blocks and the link for jigging up these kinds of structures. So I was rigging up all kinds of material that I had previously welded in an attempt to hold something steady so I could get a tack on it, run a weld around it, or whatever.
The advanced version of this course, which will hopefully be soon (if not this year yet) will focus on structures and fabrication. Things like fuselage construction, stainless exhaust systems, and other things more pertinent to homebuilding (or motorsports, or anything else of the sort). I think that if they make the first course a prerequisite, or some amount of TIG experience beforehand, it would be beneficial to all. Otherwise I suspect it's going to knock some folks for a loop. Throw somebody a couple pieces of stainless tubing and tell them to join them without having touched a torch might be a bit much.
Long winded reply, I know. But glad to share this experience with others who may be considering the same. There are several experienced welders in this group, so always happy to discuss the topic!
~Chris
P.S. - One side note, I think that the SportAir Gas Welding Workshop really, really, REALLY helped prepare me for this. I already had a picture in my mind of what welds are supposed to look like. So I had a decent frame of reference where to apply heat and such. Being taught by Earl Luce really helped, too.
  • Like
Reactions: BJC
Little Scrapper
Jan 3, 2014
5,674
Wisconsin
Nice job Chris. It's been many years since I went to welding school but I still remember all the good habits they taught. It's amazing what some dedicated practice with these good habits will do for you.
TIG is a pretty fun process! Thanks for the update.
Little Scrapper
Jan 3, 2014
5,674
Wisconsin
When you get comfortable with control that little Lincoln you have is an amazing TIG brazing tool using Sil-bro.
I just built a pipe rack for my shop, 100% TIG brazed for the heck of it. You're really gonna have some fun going forward. Once you get to know your machine well you'll be doing all sorts of things with it.
Winginit
Jun 12, 2016
811
x
Very good job Chris, and an excellent post with the pictures and all. This should encourage a lot of others to give Tig a try. If you wear glasses, especially bi-focals, try pushing them back a lttle toward your face before you drop your helmet. I have found that gives me a clearer focus than where they normally sit on my nose for reading. If you need to buy some cheap glasses to experiment with, try one of the "Dollar" stores. You will find that the distance from your eyes will affect how clear your view of the puddle is. If you find a cheap pair of reading glasses with the correct magnification and then switch to a helmet cheater, the slight change in distance may change the view even though its the same magnification. Many people don't realize they don't have a really clear view of the puddle because they are concentrating so hard on everything else. Thats something a lot of mig and gas welders might want to think about too. Anyway, good job !
