Close? The PPL is double the time and cost of the SPL. I don't consider that close.
For me and the type of flying I'll be doing, the SPL makes perfect sense. Although I would like to have a higher allowable cruise speed, which would open up more choices in AC, I can live with the restrictions. The difference in training between about $3000 for SPL and $6000 for PPL is significant.
BTW I could just kick myself for not going through with it and getting my PPL in 1991 (I logged about 2 hours total) when I could have gotten my PPL for about $3000!:depressed
Mike
I used to think exactly the same thing... 20 hrs vs 40 hrs - right? I even started training with the Sport ticket as my goal - but experience has changed my mind.
Unfortunately, the reality is that the FAA wants you to know almost as much for Sport as for a PPL. Don't believe me? Then go make a list of all the flight training lesson topics for both licenses (stalls, steep turns, ground reference, instrument work, X-country, etc.) Two differences stood out for me:
1. The Sport license doesn't require as much instrument training (hood time) - yeah, you can avoid the instrument requirement... but the only LSA I can rent breaks the magic Vh speed (87 knots, right?), so I'd have to get at least a little hood time.
2. The cross-country requirements are smaller... but when I planned and flew mine it didn't seem like it would have been all that hard to have gone a little farther and stopped at a third airport. I would guess that an extra half-hour of planning and somewhat less than an extra hour of flight time would have turned my sport x-country into a PPL x-country.
I know that there isn't nearly enough data for good stats on number of hours required (especially with the recent changes)... but my gut feeling is that the training time difference is more like 5-10 hours instead of 20. My CFI has put together a training plan for sport to private transition and his minimum is 12 hours of extra training - but the thing to keep in mind is that the plan includes 5 hours of "do-over" cross country time because my sport pilot cross-countries weren't long enough to count. :tired:
The knowledge tests are also pretty similar... just add VOR interpretation and some extra airspace questions to the sport-pilot test and you get the PPL test.
The BIGGEST thing to keep in mind is aircraft availability. If you're planning to build or buy an LSA and then use it for training, then you can ignore that problem. If your plan is to go to the FBO and rent an LSA, then I wish you lots of luck. I've had pretty bad luck in that area... Of the 3 LSA that I've flown, only 1 is currently available for rental - and I believe that it's now the only rental LSA in the St. Louis area. And that last bit is the primary reason I'm switching: There are 4 other airplanes I could easily rent at the FBO (2 172s, 2 152s) that has the LSA, and there are 4 other FBOs that I could rent from.
Do I think Sport is a good starting point? Not at the current time - unless the medical thing is a big deal for you. I can see where the special issuance process could become an expensive pain if you had diabetes or resolved heart problems or kidney stones or <insert minor problem here>. Starting out as a sport pilot will make more sense once there are more LSAs for rent... but I can't imagine that any LSAs are going to replace the 152s and 172s that are on the flight line right now. Maybe in 5 years it will start changing as the busier Cessna Pilot Centers start to sell off the used SkyCatchers that they don't even have yet. :whistle:
