special ??
David Moxley
Apr 6, 2013
86
KCOE , Idaho
Today I got the skin fitted to the leading edge fuel tank,and removed it them the jig , now to final trim the edges to shape disassemble debur all the holes, and countersink them. Still have to install the fuel cap at the tip & fuel pickup strainer & fuel level sending unit. Still a lot to do until it goes together for good.C490025A-3B95-4C4E-9AC5-8A502B269953.jpeg
David Moxley
Apr 6, 2013
86
KCOE , Idaho
1EA7C493-CC31-42F3-A1BA-139F1DDE1CA7.jpeg A7FD024B-EBF3-480E-B9C6-6032709A10BA.jpeg 7778FF0D-B718-4520-901C-C2FD4F429FB4.jpeg
Today finally started riveting the spar cap strips to the center section bulkhead & inner center section spars . Been a long time coming to this point , rivets are turning out nice . Couldn’t have done it without the big rivet squeeze in the background .46E6458E-EC07-4AE5-AE88-8833FDE00379.jpeg
David Moxley
Apr 6, 2013
86
KCOE , Idaho
Here some pictures of the tank in the jig , and both tanks on the table with the center section.
Finally finished the second leading edge fuel tank to the point where it can come out of the jig. These tanks have washout and are tapered, and are a real bear to get right . They will be removable like RV leading edge fuel tank . Tomorrow should get the rest of the rivets to finish riveting the center section , then get back to work on the tanks . 359D7370-4EE0-4921-B9E4-B2510C2FF1FD.jpeg 2194E3D3-4C04-4C0A-834C-787FFA21A4C4.jpeg 177B67D3-04AB-473F-BC9C-62BAA3E31BE1.jpeg 0414A691-9AA1-4EF0-B94B-0D66523BD00B.jpeg 68DFB59B-EC4E-4884-80D0-D046CD4ACB22.jpeg
David Moxley
Apr 6, 2013
86
KCOE , Idaho
Yesterday I finally got the outer spar all lined up to drill the attachment bolt to the center section. Holes are drilled undersized, and the each bolt is measured,and each hole is reamed to fit. Very time consuming, with are lot of measuring going on to get it right , you only get one chance ! Waiting on the NAS bolts now. Almost 70 bucks each , Ouch !83108133-97A3-418E-B539-798FE4B0D4F9.jpeg C4F77117-7DB2-411F-AE6E-AFDCC988B6BB.jpeg AFAF81F9-A8C6-479E-BB0E-64CBEAD2F272.jpeg
