I don't recall exactly. Actually I didn't cut the transmission off, I just removed all the gears and shafts and plugged the holes. The prop shaft bearing carrier replaced the original clutch cover. I think the finished engine weighed a bit under 30#, I don't recall if that included the exhaust. I still have it but haven't messed with it in years.
DANG ; thumpertalk (.) com said the KX100 engine, will put out
28-hp ; and you got a really low weight , on your finished engine !!
You bet, i gave ya a , (Like) on your post !
28hp would make both my Atos and Exxtacy fly ; only thing holding
me back is that it is a 2-stroke.
Both the engines i mentioned, are 4-strokers, and in the low 50-Lb
range ; was hoping i could loose about 15% of that, by dicing the
transmission off ? Complete rebuild kits, for both those engines , can
be had for in the $700 range ; and that included new crank-shafts
and pistons and bearings. I would go for a belt reduction from a known
source if i went that rout ; that's what interested me , in this Thread !
Can get a Polini Thor 202 , for a tad over $3k ; it's a 2-stroke , and
it might be a problem in some states in another few years ?
Bille
