Some design musings
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
Sorry Duncan, but please dont ruin your second chance to build a plane for yourself, by incorporating some of your own modifications on the structure, that could lead to (again) useless work and time..to end in a storage somwhere unfinished.
Buy plans and a "short - basic kit" if available, group by group and build per plans.
Mitja
Hey Mitja - Chill mate...
This thread is entitled "Design Musings". Shooting the breeze. Design small talk. Nothing else.
"Useless work and time"? "to end in a storage somewhere unfinished."? Be fair mate... My journey might not be simple and clear - but little of it is useless, and the fact that my build is in storage is because I have temporarily run out of money. I'm actually a bit pi*sed off at your comments. Play fair...
Sheesh...
Duncan
delta
May 26, 2011
2,215
Brookside Utah
Part Facetmobile, part Arup, I like it.
I like it too. Thanks man. I keep coming back to this one despite the tail dragger configuration and the lack of visibility at ground angle of attack. It's going to be scary for me when it's time to test it out. I hope to have a BRS by then but I'll have a back pack for sure. I'm making it out of carbon fiber golf club shafts, powering it with a mz202, and covering it with Dacron. I plan to incorporate a wing folding or detachment so I can trailer it to a dry lake bed for testing.
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
Hi again,
I'm musing again... All that discussion about Apollo's canard design got me doodling in X-Plane again, and here's where my musings have taken me, Just a first cut, mind you, so don't be too harsh...
One thing which is a bit odd is the stepped tail. I did that by accident, and kinda liked the look, so I left it. I know it's not aerodynamically optimal, but hey - this is a pleasant cruising 100hp 2-seat Side-by-side Sunday cruiser. It's not meant to be a racer... And it will certainly catch the eye. The steps could even be used as low pressure areas for exhaust extraction.
I've used the design formulas I worked out for the Razorback tandem wing, paid attention to the two downwashes, specified airfoils which will ensure the canard stalls first. I've even fitted flaps to the rear wing. Oh, and I decided to stick with a "proper vertical fin with an all-flying elevator. I don't trust those wing-tip rudders...
(If I fudge the CG) my design spreadsheets say it will fly. In X-Plane it flies like a dream. What's not to like for an afternoon's musing at the keyboard? Perhaps turn it into a pusher? With a V-tail? That ought to be fun...
Enjoy - and comments always welcome.
Duncan
Aesquire
Jul 28, 2014
2,427
Rochester, NY, USA
That is a dead ringer for the Hirt Trio. The canard on his was smaller with no control surfaces, and his wing shoulder high and forward swept. 8 degrees. Tail was lower too, positioned out of wing wake clean and with flaps.
April 1995 Kitplanes magazine. Given a very good review with an O-320.
Just happen to have that issue in the reading room. I cycle back issues through to re-read the Wind tunnel articles and dream.
11,505
I call that room "the library." :) I grew up with two brothers, and that was the only place to have peace and quiet to read, especially technical stuff.
Aesquire
Jul 28, 2014
2,427
Rochester, NY, USA
The Trio was memorable because there have been few successful 3 surface planes.
The B-1b has a small canard used for gust relief at low altitude high speed flight but it's computer controlled.
I suppose I could say your musing is a distant ringer to a Long EZ with a tractor prop and tail ;)
Btw... I like it. Perhaps too much sweep unless you put the engine behind the cockpit like a Stemme. ( on my short lust list if I win the lotto )
7,545
My heart and eyes love it, but my brain says that the CG is way to far forward for that wing planform. The canard would be carrying more than half the weight with only a fraction of the area, so its loading would be very high and the main wing would be doing very little. If it were me, I'd duplicate the rear wing forward to make it a tandem, lose the tail surfaces, clip the outer foot or so from the rear wing and add endplate rudders to make it a Mauboussin-type tandem with no tail at all.
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
Hi,
The Hirt Trio - I could only find a single picture of it. And not a great one for seeing its lines. Any idea where I could find others?
Duncan
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
HI,
As I said in the first post - I had to fudge the CG in X-Plane (and in the SS) to make it fly. Actually, if I put the CG in the vicinity of the cockpit so that adding a passenger wouldn't make too much difference, the main wing has to be swept forward almost 20 degrees. I tried that, but it looks plain silly.
I also tried it as a pusher, which sorts out the CG issue quite nicely. But pushers? Meh... I'm not so sure...
Duncan
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
I'm about to turn in for the night, so here's a revival of an earlier design I was doodling with some time back. This time I've done a bit more work on the wing placement, the actual computed CG and have been playing with flaps/elevators and aileron placement. Currently deploying flaps produces a nose-down moment, so I have some more work to do. Oh, and the artwork is a bit shonky too.
I think this one might actually have some merit for a two-seater (100hp).
Duncan
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
A final effort for now...
I got to thinking how I would build the V-tail, and it seemed like a nightmare to me. So I reverted to a "standard" tail, and put an all-moving elevator at the top. I did this not because it looks cool (it does), but because I wanted it as far from the CG as possible to maximise its lever arm. And because the tail rakes backwards (yes, I know a number of you don't like this, but what the hell...) putting it on the top made sense. It also puts it out of the way of the wing downwash as much as possible. In fact, it gets less than 20% of the downwash angle experienced at the wing TE.
So, now I have a cross between a tandem wing design and a biplane.
Front wing:
15ft span
Rear sweep 18deg
Wing area 30.2ft^2
Airfoil: Eppler E290
Incidence: 3 deg
Rear wing:
15ft span
Fwd sweep -18deg
Wing area 30.2ft^2
Airfoil: AS5054 (selected because it stalls 2 deg later than the Eppler)
Incidence: 2 deg (giving me an effective 3 deg "safety margin, even taking downwash into consideration)
Downwash angle at rear wing at the stall: 8.6deg; Downwash at rear wing: 2.15deg
Stall: 43kts clean
Power is still the 50hp VE Big Twin (I have yet to test ths claim, but suspect it is overly optimistic)
Cruise (80% power) should be a respectable 120kts
Well, there you have it. The latest product of a mind slowly turning to custard while I continue looking and waiting for work.
Duncan
PIX:
(1) The F1-X1 on the drawing board
(2) On the runway
(3) Airborne
(4) On the way to New Zealand...
F1-X1 on the drawing board.jpg F1-X1 on the runway.jpg F1-X1 airborne.jpg F1-X1 on its way to NZ.jpg
rtfm
Jan 3, 2008
3,233
Brisbane, Australia
Hi,
I'm at it again. This time I'm inspired both by HITC who has encouraged me to think along the lines of a Part 103 design, because in the horrendously overcrowded marketplace for light aircraft, there seem only to be two niches - STOL and Part 103
(I'm not sure I mentioned this on the forum, but I had to store my entire workshop in a container and park it on an industrial lot - together with the plugs. Unfortunately, the plugs couldn't fit inside the container, so I had to take my chances and store them on their stands next to the container. I covered them with tarpaulins and plastic sheeting, and just had to hope for the best. Then along came the biggest storm Brisbane has seen for 30 years. Huge hail smashed everything in its path - including my plugs. Water then got in, and the underlying MDF started to swell. Long story short - the plugs are past redemption.)
I still am not in a position to start building again - but at least we have secured a new place to live, which has one one but two double garages. The second of the two is going to be my workshop. We move next week. But the thought of starting all over again is heartbreaking - but the one good thing is that I have learned some very valuable lessons about how to build a plug. Next time round it will take weeks, not years.
And hence my thoughts turning once again to designs.
After having read all 44 pages of the Electric Lazair thread on the RC forums, and speaking to HITC about series hybrid electric planes, I spent most of today playing around with a possible Part 103 series hybrid concept which could be built for under $10k (including engines). It's basically a reworking of an earlier push-pull concept I was playing around with some time ago - but on a very much smaller scale. I think it's cute...
A 20hp ICE goes up front
A 15hp or so electric motor on the rear
Both run flat out for T/O and climb - which should be brisk
The ICE then does all the honours during cruise, as well as doing double-duty charging the batteries. Charging should take (I'm led to believe) about half an hour, meaning that the batteries should be fully charged for emergencies in prettyshort order. I like the idea of electric power on standby should the ICE quit.
Wing span: 28ft
Wing area 105 ft^2
Stall: 28 mph (clean) - but I'll fit Junkers flaps I think
Cruise: 75kts
Empty weight (including batteries): 265lbs
So I have some more work to do on the speeds and weight fronts - but I'm getting there. I still need to estimate the CG more accurately, and check all my math. But I think it is reasonably accurate as it stands. The fuse will be made of 4mm cork/glass sandwich. Wings D-Tube (2mm cork sandwich) and Depron aft of the D-Tube. Carbon (graphlite) spar.
Looking for: decent 20hp motor. I hate two-strokes. Might have to just bite that bullet though. Anyone know of a decent 20hp Rotary? Even on paper it is difficult to meet the weight limit. Building will add many pounds I fear...
Enjoy - and (as always) comments welcome. These are my first drawings - so they're a bit rough...
Duncan
F1-e1 on runway.png F1-e1 on runway2.jpg F1-e1 airborne2.jpg F1-e1 airborne.jpg
Jay Kempf
Curmudgeon in Training (CIT)
Apr 13, 2009
4,008
Warren, VT USA
Hi,
Wing span: 28ft
Wing area 105 ft^2
Cruise: 75kts
Duncan
View attachment 38169 View attachment 38170 View attachment 38171 View attachment 38172
Oh come on Duncan,
That is way to conservative and sane. What happened?
