Small Hybrid Electric Aircraft
RonL
Jan 9, 2007
502
Texas
It might help if you described the source of energy and the power input into the propulsion system, then the nature of the thrust and the power out of the system.
I would say a conventional power system, single or twin or some other configuration for takeoff and climb to speed. Somewhat minimal battery storage (for weight consideration) and two power recovery tubes that have counter-rotation airflow for torque equalization.
Conditioning the velocity of airflow inside the tube will move the vast majority of mass and temperature into a high friction driving flow that is moving at an accelerated spin speed, far above the speed of entrance air.
(vortex tubes have air spin at over 1,000,000 rpm in a 1" pipe, from a 1/4" tube @ 100 psi) of course, a much larger design would reduce spin speed by many times. My older refrigeration manual described the power of friction inside the tiny 3/4" tube, to be equal to 1/2 horsepower (this resulted in heat transferred to the tube shell)
I believe an image of basic structure and operation in one's mind, must precede any evaluation and analysis of numbers and size.
Edit to add content (always forget to say the important things)
That friction driving flow will power a generating stator and possibly assist in a mechanical form of drive assist to the electric discharge fan, which should be producing a slight positive thrust.
The power to the rear fan will determine if this is just an energy recovery system or a possible additional power source to aid in flight.
Sockmonkey
Apr 24, 2014
1,934
Flint, Mi, USA
While pondering the stirling and it's variants like the manson engine for hybrid purposes, I came across this thing.
The principal is simple. One piston pumps air into the tube which is then heated by an external source, and the expanding air is vented into the second cylinder turn the crank. You get the clean constant burn and flex-fuel capability without anything fiddly or complex.
Seems pretty nifty.
Now what if we replaced those pistons with a pair of positive-displacement rotor pumps? Then you get vibration-free smooth power delivery that would be really good for spinning a generator.
emir_82
Jun 25, 2014
54
Rosario
Yes,
I assumed these costs in the $5000 for the Hybrid system. That is at cost for a DIY setup.
That will still need the electric engine, prop, controller and the small battery bank costs to be added for the motive power.
But you "already bought" that other stuff. So you have to think the exchange of a fraction of the battery pack for the hybrid system in therms of price and weight.
For the sailplane I need "only" 5kwh in total. In that case it doesn't worth it.
8,588
Well, I did mention two times what should imply the plane is moving forward but did not assign a speed.
The velocity of the plane would, by all means, determine the energy carried into and through the tube, the recovery of energy, either electric or mechanical or both, will be based on internal design.
I assume you meant ambient air as sitting motionless on the tarmac.
So you are going to fly a plane at X mph through the air, slow some of that air down to extract work from it?
Sockmonkey
Apr 24, 2014
1,934
Flint, Mi, USA
A NACA cowling should work for reduced cooling drag/thrust production just as well for an electric motor as it does for a radial.
litespeed
May 21, 2008
1,557
Sydney
So I can do some rough calculations and mud map a system, I ask the following.
What is the airframe?
What is the power for takeoff and cruise?
Min power for level flight?
How long do you want as power flight time?
What weight can it carry as engine systems and fuel in total (ie as any power system, either gas powered or electric)
And anything else you have as requirements?
Does it have available space to place the hybrid and batteries?
Where would you place the motive engine- ie in a pylon or nose?
Then we can work out if a system can be designed that is suitable.
The same invitation is open to anyone and any design type but slippery is better.
Cheers
litespeed
May 21, 2008
1,557
Sydney
Sockmonkey,
Interesting as far as stirling engines go, but they all have very poor performance for anything but oddities and desktop ornaments.
They just can't make enough grunt to be useful as they are external combustion engines.
Much better to use a two stroke which is a very simple engine with very few moving parts and bags of power for size and weight.
Grumpy Cynic
7,287
I agree - not that it really matters.
2 strokes have a bad reputation with regard to efficiency, but if tuned to one RPM or operated in 4 stroke mode, they can do very well with regard to BSFC and still retain their good power to weight ratio.
litespeed
May 21, 2008
1,557
Sydney
A well designed stroker is ok fuel wise and in the hybrid situation its super light weight and power more than overcome a bit more fuel use.
Sure once we scale things up, then a four stroke engine tends to come out on top.
However a injected two stroke is entirely different and can be very economical when done well.
Sockmonkey
Apr 24, 2014
1,934
Flint, Mi, USA
Sockmonkey,
The killer for stirlings is the power to weight ratio and the fact that best efficiency means the cylinders need to be hotter than a normal IC engine would run, requiring expensive alloys.
The lack of throttle response isn't an issue for hybrids and/or electrical power generation.
The manson versions have a better power to weight ratio and cooler cylinders because they heat the air charge outside the cylinder and dump it once it's been used to push the piston instead of trying to cool it back down in time fort the next stroke.
http://manson-ericsson-hae.blogspot.com/p/ma.html
It's not all that different from a conventional ICE in that it takes in cold air, heats it so it expands and does work, then expels it.
litespeed
May 21, 2008
1,557
Sydney
For this design exercise I will stick to know and common technology that can be easily replicated or purchased.
I do not want to have too many new technologies involved as this leads to lots of unknowns and pushes up the risk profile for operation in the air.
So - be using common off the shelf stuff were possible.
In this case that means two stroke, rotary or unlikely but possible a four stroke.
litespeed
May 21, 2008
1,557
Sydney
Thats what I am waiting for, a proposed airframe to do a study on.
Cheers
