Slow delta wings?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by deskpilot, Jul 21, 2009.
  1. Aug 15, 2010 #101
    BDD
    BDD
    BDD
    Apr 2, 2005
    388
    3
    WI
    GTEX-09
    What was the cause of the instability which caused the crash? C.G. location, airfoil selection, some wing or elevon configuration issue, etc?
  2. Aug 18, 2010 #102
    gtex09
    gtex09
    gtex09
    Apr 13, 2010
    38
    20
    France (Lille)
    Hi BDD,
    Well, I guess that was because I made too much changes in the plan shape between the 05 and 06 version....
    Actually, if you look in detail to v06, you will see that the wing size is really much more smaller than the v05, for te same length of airplane.
    It was much more sensible to the CG location than the previous version.
    That's the reason why I came back to the same plan form for the v07 version.....
    GTx
  3. Nov 10, 2010 #103
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,104
    188
    Hi guys, been a while since I last posted. Here are a few images of my Eagle-Ray. Still a long, long way to go. The green represents F/glass although the turtle-deck side walls and all under side surfaces might be fabric as there are no con-cave curves included. The frame is riveted alloy, either square or rectangular.
  4. Nov 10, 2010 #104
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    974
    680
    Dallas Texas
    That's really cool Doug. Hope to see more progress.
  5. Dec 28, 2010 #105
    ThadBeier
    ThadBeier
    ThadBeier
    Dec 28, 2010
    79
    16
    Los Angeles, California
    deskflyer, this is a remarkable progression of design. I am a huge fan of low-aspect ratio airplanes -- I think they have a lot to recommend them. They can be light, very strong, simple to built, have a lot of interior volume, and aren't too fast. The Arup planes were an early example, and yours might be the most recent one. Another example of a low-aspect ratio plane, not completely unlike yours, is the Pelican -- see pelican
    I agree with your analysis that your wing area will have to be rather large to get the stall speeds that you want. The Vermeer wing mentioned upthread stalls at way too high a speed, but it's tiny -- 10 ft long and about 15 ft span. (3.3m by 4.5m) Making it a bit bigger is a good idea. His design was a true delta (except that it isn't swept enough, I suppose) and he needed the dihedral to eliminate dutch roll. Your wing has much less sweep, and probably won't have the odd rudder response that the Vermeer wing has.
    Good luck!
  6. Jan 1, 2011 #106
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    956
    189
    Canton, GA
    Me too.
  7. Jan 2, 2011 #107
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,104
    188
    Thanks guys. Haven't done much lately as I got side tracked with the Ring Tail project, another 'out there' design. Maybe I'll build something one day instead of just dreaming.
  8. Mar 21, 2011 #108
    ThadBeier
    ThadBeier
    ThadBeier
    Dec 28, 2010
    79
    16
    I've been thinking about your design for a while, and have come up with something similar for similar reasons. I am struck by how similar this is to the RANS S-11 Pursuit -- check it out!
  9. Mar 22, 2011 #109
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,104
    188
    A few years back, I saw a picture of the S-11 but it was parked behind another aircraft, and wasn't referred to in the write up. Since then I've tried to find out what it was and yesterday, I finally found it. A very nice looking plane and it's a great pity it didn't make it into production. I'm sure it would have been a winner in only they could have solved the problem that caused the second aircraft to crash (seniors moment)
  10. Mar 22, 2011 #110
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    The aircraft was plagued by control and stability problems due to the wide fuselage. This is what I try to warn folks about when they endeavor to design aircraft with strakes and wider bodies. The geometry can set up various forms of vortex flow, which tends to be unpredictable and very destabilizing due to non-linear behavior. Secondary issues also include pressure shifts not coordinated with wing characteristics and blanketing effects.
  11. Mar 22, 2011 #111
    Super Moderator Staff Member
    Jul 30, 2005
    13,963
    5,577
    Everyone was excited about the S-11 when the proto started making the airshow and magazine circuit rounds. The big question was, "When are you going to release kits!??!?" The company played it cagey, saying "this is only a concept demonstrator" - for a transport airplane, of all things. Later it was revealed that the airplane was a real handful to fly, for the reasons Orion states above.
  12. Mar 22, 2011 #112
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    956
    189
    Canton, GA
    I don't even pretend to be an Aerodynamicist but just eye balling it I don't care for how the forward fuselage is blended on the S-11.
  13. Mar 23, 2011 #113
    ThadBeier
    ThadBeier
    ThadBeier
    Dec 28, 2010
    79
    16
    Back in the day, there were not the computer power or the publicly-available software to do simulations of these vortex flows. Would it not be possible today to design a plane that could reliably take advantage of them, rather than have them make the plane difficult or dangerous to fly? And I know, I've seen the abomination of the vortex-breaker on the F/A-18, that was made necessary by exactly these same kinds of missed-predictions (even with the resources of Northrup to do the simulation and testing.)
  14. Mar 23, 2011 #114
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    Possible? Maybe. Affordable? Not to the small airplane company. But the biggest problem here is the lack of applicable design experience more so than simulation software or other technologies. The S-11 was a radical departure from their regular product line and done by a seemingly unqualified designer to take on something that unique.
  15. Mar 23, 2011 #115
    11,925
    3,414
    If I remember the first S11 crashed after takeoff of an engine seizure almost killing the the head honcho, and the second plane crashed after 250 hours when a regular employee decided to test the slow flight and spun it in. I know a third was built but with such bad karma it was probably time to quit.
  16. Jul 4, 2011 #116
    delta
    delta
    delta
    May 27, 2011
    1,979
    200
    Brookside Utah
    Hi Doug
    I'm going to second the motion that your CG will be to far forward in your current configuration. I believe it's marked close to right in your drawing, but in full scale I don't think the aft portion of your airplane will offset the weight of the engine and pilot. Build some rubber band thrown flying models with paper, balsa, and then a powered RC to fine tune your CG. You might consider a mid engine, a push pull twin, or a really light pusher to keep your cranked arrow configuration. I think you will find that it will fly nice, land on a dime, but be anything but slow.
    If the tractor configuration is more important to you than the cranked arrow, then you can have an unstraked leading edge. You will probably wind up with more than a 60* sweep. I've gone from 45* to more than 90* with RC and the more sweep the further aft the CG has to be.
    I wish Jubaru or Rotec would build a nice long stroke, big bore, opposed twin for under $500, but I'm not going to hold my breath.
    Good luck with your project and wish me luck with mine. I'm going for a super light, roadable amphibian. I'm in the early stages and still looking at power options before going to much further. I've even considered a 2a016 genset running a bunch of giant outrunners.
    Rick
  17. Jul 4, 2011 #117
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,104
    188
    Hi Rick, thanks for your input. I haven't done a lot lately except rethink my wing profile. I think I've stretched it too much and now it's too shallow, something like 9.5% at the root. Should be in the region of 15% I believe.
    I'm in the process of making a chuck glider but I don't think it will provide and useful info with regard to lift or AoA. Still, must keep dreaming
    Good luck with your design, don't understand your final sentence though.
  18. Jul 4, 2011 #118
    delta
    delta
    delta
    May 27, 2011
    1,979
    200
    Brookside Utah
    Hi Doug
    Everything's going to change a lot when you start working on the full scale anyway. The models are a good way to explore stability and CG. When you build a bunch of them you get a feel for what works better and why.
    The 2a016 genset is a small US military generator. The giant outrunners are brushless electric model airplane motors that the outside housing rotates. I'll probably use a belt reduced two stroke swinging the largest prop I can.
    Later...
    Rick
  19. Jul 5, 2011 #119
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,104
    188
    The old adage .."Try, try and try again" comes to mind.
  20. Jul 5, 2011 #120
    delta
    delta
    delta
    May 27, 2011
    1,979
    200
    Brookside Utah
    Choices, choices, and yet another ^&*@#$$* choice... Here's my current one and I'm sticking to it, maybe...
    Later...
    Rick
      File size:
      40.3 KB
      655
      File size:
      74.6 KB
      2,554
      File size:
      18.5 KB
      534
