Single Tube Fuselage idea
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by FritzW, Aug 11, 2016.
  1. Oct 11, 2018 #221
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    Could do that, though you will have to mount the engine higher.
    Hmm, maybe use a belt drive to keep the engine low and still clear the water.
  2. Oct 11, 2018 #222
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Have engine drive generator, have generator power electric motor(s)
  3. Oct 12, 2018 #223
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,115
    199
    I think we have a serious thread drift here. Care to get back to the title subject guys.
    proppastie likes this.
  4. Oct 22, 2018 #224
    saini flyer
    saini flyer
    saini flyer
    Mar 12, 2010
    438
    120
    Dallas, TX
    I am wondering why no one has mentioned Genisis slipstream yet!
    Instead of the large spacing between the top tubes of the tail cone, make the spacing at par with the bottom tubes and mount the engine upfront. Keep all of Fritz's single tube concept and use cross beam members riveted as in the slipstream for a single seater or even a side by side fuselage build.... BTW, I have no idea how to bend to correct accuracy to mirror both sides of the fuse....
  5. Oct 22, 2018 #225
    Super Moderator Staff Member
    Oct 19, 2003
    6,167
    3,468
    Wing structure will have to get beefy indeed to survive wing pitching moments plus lift through the fittings at the strut connections...
    Two conventional struts per side plus four short struts from fuselage to wing center section will allow a lot less weight, if conventional...
  6. Oct 22, 2018 #226
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,578
    542
    Not sure they have to be THAT beefy. The span is short already, and then it's divided into 3 pieces. Assuming the wing pivots around the strut attachments, I'm not sure what the wing pitch control is, but that can probably be solved. A thick airfoil with a moderate pitching moment, such as a 23018, might help with wing torsion issues. A movable elevator would, of course, make things simpler.
  7. Oct 23, 2018 #227
    4,060
    1,188
    TLAR aerodynamics and loading, and stress analysis.....?
  8. Oct 23, 2018 #228
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,578
    542
    Well, we know there are light airplanes of comparable size with cantilever wings. The spans involved here are much shorter. We also know of light airplanes of comparable size and thinner wings that have ailerons. If we're not using an extreme airfoil, it won't have a larger pitching moment than you get with ailerons. If those other aircraft can take the pitching moment, our hypothetical, thicker wing ought to as well. So it may be TLAR, but it's not necessarily wrong or invalid.
    A conventional setup could be made, of course, lighter. Anyone know why the Pou doesn't use an elevator?
    Sockmonkey likes this.
  9. Oct 23, 2018 #229
    6,599
    5,380
    The elevator requires essentially two separate flying surfaces, the stabilizer and the elevator. One additional spar to carry the hinges on one side, and one leading edge spar on the elevator to carry the hinges on the other. Even if you mounted the elevator on the front wing, making it a canard of some sort, there are still extra parts. So Mignet's design eliminated the extra parts for the separate elevator regardless of whichw ing it would have been mounted on.
  10. Apr 8, 2019 #230
    billyvray
    billyvray
    billyvray
    Aug 17, 2005
    728
    236
    Newnan, GA
    what kind of generator do you refer too? I'm genuinely curious about an application I have in mind.
  11. Apr 8, 2019 #231
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
  12. Apr 8, 2019 #232
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
  13. Apr 8, 2019 #233
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    So looking at the Launchpoint Hybrid 45kw. It turns at 6000rpm. If you wanted a more "sedate engine" like 2000rpm or 3000rpm just make the rotational mass a greater diameter. It is the velocity of the magnets passing the windings that makes power not the revolutions of the crankshaft.
  14. Apr 8, 2019 #234
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    It is the Holbach array that makes it possible to make the generator and motor light enough to be practical.
  15. Apr 10, 2019 #235
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    Thank you. While I do engage in a bit of TLAR, I tend to base it on pre-existing configurations and structures known to work.
    For that particular one, the wing pivots like on a pou, with a fixed elevator (but ground adjustable) that's only there to provide pitch stability.
  16. Sep 29, 2019 #236
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,762
    190
    A few ideas
  17. Sep 29, 2019 #237
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,762
    190
    One of my favorites, beside the Ranger in construction-
  18. Sep 29, 2019 #238
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I like your idea for changing the lower tube (yellow line in the sketch). I think it could simplify more things than it complicates.
  19. Sep 30, 2019 #239
    Aesquire
    Aesquire
    Aesquire
    Jul 29, 2014
    2,384
    976
    Rochester, NY, USA
    A trick for making mirror image or identical bends is to make the final length cuts after bending.
    You get part A to the shape you want, then bend, tweak, and get the bend in part B the same. Getting the bend the same is relatively easy. Getting them in the exact same fraction of an inch location on the tubes is harder. So cheat by leaving excess length on both ends. The final cut off then determines the bend location with fair precision.
    This doesn't work if you are using the full length of available tubing, unfortunately. In that case, Mark the tubing with magic marker on the circumference at regular intervals, and along the length every 45 degrees, to give you a visible grid to reference, tube to tube.
    ElectricFlyer and Sockmonkey like this.
  20. Sep 30, 2019 #240
    rotax618
    rotax618
    rotax618
    Nov 1, 2005
    747
    305
    Evans Head Australia
    D8822245-E9E4-470A-9DF9-27181674E080.jpeg 128313DC-6000-4BF3-8198-FDA7DC224FE8.jpeg My single tube design.
    cheapracer and Hephaestus like this.
