Single Tube Fuselage idea
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by FritzW, Aug 11, 2016.
  1. Aug 27, 2016 #201
    6,640
    2,532
    Yes, but the down force is pretty small. Sin 8 degrees is only .139. So if you have 100 pounds of thrust there will be an additional 14 pounds of force the wing needs to lift. The forward thrust component is cos 8 deg = about .99. So you still have 99 pound of propulsive thrust to move you forward.
    Sockmonkey likes this.
  2. Aug 27, 2016 #202
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    Or... we could even split this thread into "Single Tube Fuselage idea" and "Flying Wing idea"
    If they gave Academy Awards for the best thread hijack... :gig:
    cheapracer likes this.
  3. Aug 27, 2016 #203
    6,599
    5,380
    I didn't know that a tailless layout represented a hijack to this concept...
    But in the spirit of Fritz' comment: : "I'm so honored to receive tihs award... I'd like to thank the Producer Charles Fauvel at Ailes Volante Entertainment, our Director Jim Marske and everyone over at Pitch Damping Management, those rascals Al Backstrom and Paul MacCready at Plank Studios, and our editor JC Debreyer who brought this down to a manageable size. A special thanks to my agent Carl Goldberg and all the gang at VooDoo / Fox 35 agency, they've been with me since I was just a kid...."
    Pops, litespeed and erkki67 like this.
  4. Aug 29, 2016 #204
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,763
    190
    :roll::roll::gig::roll::gig::roll::gig:
  5. Aug 31, 2016 #205
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,763
    190
    a little bit less radical, a 3 tube fuselage?!
    ScaleBirdsScott likes this.
  6. Oct 2, 2016 #206
    4,060
    1,188
    Just discovered this thread, sorry I have been sort of busy, ....must be ESP anyway firming up my design. Decided to keep .120 wall except for at splice the 7075-t6 is bad for stress cracks. I took a hit in weight but saved money on machining and eliminated a tube. Aft tube is 6061-t6 x .049 wall. These tubes weigh 28 lb. Wheels (2) are 5 lb. About as far as I have gotten at this time.
  7. Oct 9, 2018 #207
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,763
    190
    For sure an Affordaplane contender if built.
    It’s a bit more complex, due to the round tubing used and their bending.
    On the other hand, it gives a more homogeneous looking fuselage.
    For a slight better rigidity of the tail cone, a lower longeron could be added, like on the Dream Classic
  8. Oct 9, 2018 #208
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    When I saw the title of the thread I envisioned a tube the size of a culvert.
    lr27 likes this.
  9. Oct 9, 2018 #209
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    Sooo...
    [​IMG]
  10. Oct 9, 2018 #210
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Pilot in front engine in back.
  11. Oct 9, 2018 #211
    10,242
    6,964
    It will be tough to transmit wing pitching moments through that strut arrangement.
    wsimpso1 likes this.
  12. Oct 9, 2018 #212
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    It's either free to pivot, or alternatively we can use a fixed elevator and control the wing tilt like they do on the flea. Whichever you think would work best.
  13. Oct 9, 2018 #213
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Make front part of tube a Hull and have the pilot sit in the nose ahead of the spray. conventional controls.
  14. Oct 9, 2018 #214
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    Well, for a seaplane I'd just do a pusher flea type design and use a pontoon float for the hull like so.
    [​IMG]
    cluttonfred and Hot Wings like this.
  15. Oct 9, 2018 #215
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    That looks fun huh!
  16. Oct 9, 2018 #216
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Lets see 254lbs plus 30lbs for the hull equals 284lbs. It might work huh? Sponsons? Could get another 20lbs gross and they probably wouldn't weigh that much.
  17. Oct 10, 2018 #217
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    I know right? It's the perfect form for a seaplane. This would sell.
  18. Oct 10, 2018 #218
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
  19. Oct 10, 2018 #219
    6,886
    2,522
    Love the amphibious flea but why a pusher? At that scale nobody is climbing out over the bow, and putting the engine on the nose let's you use a longer prop and put the variable weigh the pilot closer to the CG. What about a Pouchel II engine wings and tail your hull above?
  20. Oct 10, 2018 #220
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    I like pusher better.
