Single-ignition VW
cluttonfred
Feb 13, 2010
10,741
World traveler
The traditional, bone-simple VW conversion for a Volksplane is a single magneto, on or grounded, that's it. A few years ago I started this thread sharing the recommendation from Steve Bennett of Great Plains that an ordinary 009, blue coil and battery with a wind generator or just dead-drain was his recommendation for a simple, lightweight, single-ignition VW aircraft conversion. The wind generators don't really appear to have taken off, pun intended, but there are still a host of options. What do folks think about these options or about relying on a single ignition in a VW in the first place?
1) Stock 009 distributor, blue coil, battery with or without alternator/generator (the original, points need adjustment);
2) Same as above but the with drop in electronic ignition 009 conversion and associated coil (no points to adjust, draws more current);
3) Same as above but with Davis Unified Ignition (GM HEI components) with integrated distributor/coil unit (easy to install but a big honking thing);
4) Same as above but magnetically or optically triggered electronic ignition not based on 009 distributor (more expensive, may not work for hand prop);
5) Vertex magneto (if you can find one, expensive, even bigger than the DUI, but no electric required);
6) Slick 4316 aircraft magneto (expensive but no electric required);
7) Slick 4200 industrial magneto modified for aircraft use (cheaper but olive green ;-), no electric required)
8) E-Mag self-powered electronic ignition (expensive, will still require battery for start, may not work for hand start).​
