Shoulder wing unpopularity
Discussion in 'Hangar Flying' started by stanislavz, Nov 9, 2019.
  1. Nov 15, 2019 #101
    10,029
    6,777
    Has anyone flown an airplane with the wing at eye level?
    I have always thought that having the wing at eye level would be the best position for visibility, because of the sight lines just above and below the wing and the ability to bank to clear the view blocked by the unbanked wing.
    BTW, the J-1B, -5, and -6 are among my favorite designs.
    Battler Britton likes this.
  2. Nov 15, 2019 #102
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,666
    4,075
    Australian
    You could try 'Grape' for FEA, and a simple game called 'Bridge Builder' that is very educational about truss stuctures, and has a simple FEA tool in itself.
    stanislavz likes this.
  3. Nov 16, 2019 #103
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,215
    1,437
    Marion, Ohio
    I have put considerable thought into this problem.
    What I came up with was the wing just below eye level and swept back (leading edge) at about 15 to 20 degrees. And positioned so that where the leading edge meets the canopy would be right at the seat back.
  4. Nov 16, 2019 #104
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    A sketch ? Cant imagine how longeron will go here..
  5. Nov 16, 2019 #105
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,215
    1,437
    Marion, Ohio
    Longeron? Or do you mean spar?
    The spar would go just behind the seat, integrated with the bulkhead and fuselage framework.
    Essentially just like the J-1B except with the leading edge swept back. I don't have any other sketch.
  6. Nov 16, 2019 #106
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,666
    4,075
    Australian
    .. and this Gentleman is the inspiration for my craft, albeit not a mid wing nor dual rudders.
    The Ward Skite, designed in the early 1960's, would love to know if anyone actually knows if it ever got built ...
    mcrae0104 and stanislavz like this.
  7. Nov 16, 2019 #107
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    A nice one, and up to topic. To my opinion - any craft with spar after your seat is up to this topic. And it could be done like this (and shorter nose using more modern engine.. ) :
    [​IMG]
    Quote from here : http://www.angelfire.com/ks2/janowski/other_aircraft/Sorrell/ Some learned and wise EAAer once said that you can't design a good homebuilt without putting a little Wittman into it.
    And some more :
    [​IMG]
    And question: moving from lycoming to a kind of modern engine in rotax 912 class, and fuel tanks to wings, after spar - Where pilot head would be ?
  8. Nov 16, 2019 #108
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,100
    185
    [​IMG] Sweet, I like it lots.
    stanislavz and cheapracer like this.
  9. Nov 17, 2019 #109
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    752
    60
    Europe
    How about a 1/3 scale Skyvan with new cockpit ?
    It would be a neat single seater.
  10. Nov 17, 2019 #110
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,666
    4,075
    Australian
    Then ya gunna like moine.
    ..maybe. :cool:
  11. Nov 17, 2019 #111
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,215
    1,437
    Marion, Ohio
    That is a high wing. This thread is about shoulder wings.
    And this thread is not about scaled-down designs.
  12. Nov 17, 2019 #112
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    Need to make a sketch - but, i think shoulder wing structuraaly should be limited to pilot head popping up from fuselage in a kind of canopy 300mm height, and wings are mounted to upper longerons. And strut going to landing gear in tri gear configuration.
    And one avoid more problems, than create...
    Going strut-less or placing wing not in top fuselage longerons, will not produce nice and compact structure..
  13. Nov 17, 2019 #113
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    752
    60
    Europe
    It would be a shoulder wing design after the modification.
    As it would be just 4 meters long.
    https://en.wikipedia.org/wiki/Short_SC.7_Skyvan
  14. Nov 17, 2019 #114
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    [​IMG]
    A short sketch.. and one can add a lot of tailwind to this design,
    cluttonfred and FritzW like this.
  15. Nov 17, 2019 #115
    4,240
    1,973
    Sorry-- what is that? I see maybe a blade antenna with base mounted on a plane's belly?
  16. Nov 17, 2019 #116
    12,483
    2,524
    Fuselage with a left wing attached.
  17. Nov 17, 2019 #117
    4,240
    1,973
    Thanks for the hint, I think I see it now.
  18. Nov 17, 2019 #118
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    3,075
    2,095
    BDU, BJC
    Pity. I was hoping for a homebuilt version of this...
    stanislavz and Aerowerx like this.
  19. Nov 17, 2019 #119
    12,483
    2,524
    Aerowerx likes this.
  20. Nov 17, 2019 #120
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,215
    1,437
    Marion, Ohio
    Then it would not be a scaled version.
    I'm not going to go down that road again. Just put you on my "ignore" list.
