Svetlio_i
- Joined
- Jan 19, 2022
- Messages
- 29
Thanks Man, but the struts need to be inverted as per originalPerhaps an off the shelf item could be adapted. Bilstein Front Shock Absorber fits Rolls-Royce Camargue 1975-1987 | eBay
Thanks for the info manIf they really must look like those, you will most likely need to research the seal sizes suitable to your shock fluid, then do the detail design of the parts using enough preload on the seals to make them work and within the pneumatic pressures the FBO's can service. Then you would have to run through the orifice sizing to make the oleo part dampen fairly well. You will want to make this accessable so you can adjust the damping.
Pazmany's Landing Gear Design for Light Aircraft, Volume 1 covers the landing loads, travel, etc. He showed a couple designs but did not provide details, nor did Volume 1 cover how to design the pieces nor how to design the damping. Unfortunately, we lost him before he wrote Volume 2. Volume 1 is kind of pricey but I bet it can be borrowed through an interlibrary loan.
The alternative is you may be able to search up a house that designs and builds pneumatic and hydraulic machinery, and they would just take your required force and travel profile , then design and build for you. You still gotta know what to ask for in terms of strut force vs travel, etc.
Also shown in Pazmany's book.Many landing gear struts are simply telecoping 4130 tubes with die springs inside. Does not have to be hydraulic or pneumatic.
