Scaled Jets (F-16)
DangerZone
Sep 5, 2011
2,110
Zagreb HR
This thing is the one that worries me about your overall plan. The F16 is designed with that giant inlet so the depth of the cockpit is not so much. 60% might be aggressive. The rest of the airframe might be just about perfect though for monocoque carbon with very few bulkheads. Of all the fighters out there the wing is pretty straightforward with a ring for a spar passthrough as the only issue. Maybe you could use the two place as it has a longer canopy and higher and lay the pilot down almost ala HP18.
Jay, please notice that it is not my project but Peter's (user Acrojet), I was merely commenting an information provided on this thread.
In terms of scaling, the KAI FA-50 is basically a lighter weight 85% scale F-16. Flies fine, has solid supersonic performance, weighs tons more than Peter's plane. At 900 lbs empty mass and 2100 lbs MTOW, the wing loading of such an aircraft is still very low even if he'd further reduce the wing area. At 60% the aircraft is still pretty huge and at the planned MTOW he could do fine even in a 50% scale.
You are right about the giant inlet below the fuselage, it would ingest debris, gravel, dust and dirt from airfield runways. Your suggestion about a split inlet like on the FA-50 might indeed be a better solution, it's a good idea and up to Peter to see. I heard a rumor that the side inlets on the FA-50 was a suggestion from Lockheed Martin or some other American experts working on the project, to reduce the water/dust/dirt ingestion on wet runways that used to be a problem on the F-16 original design. This would also ease the design of the front retracting landing gear, so the FA-50 is indeed an F-16 with most design flaws resolved.
Acrojet
Jun 6, 2016
53
Gardiner, Maine USA
I'm going to hazard a guess and say aft fan, like the CJ-805-23 or CF700.
Well actually it was an "aft-fan" originally, but it was determined to be simple-yes, but the loss in efficiency, especially for such a small motor was too great. So it's been decided to move the fan to the front. It will be a little more complicated, but in the end still pretty simple and the efficiency is way better due to the fan "pre-pressurizing" the front of the compressor section thereby increasing compression ratio and giving better fuel specifics..
Very similar to the Williams EJ22
DangerZone
Sep 5, 2011
2,110
Zagreb HR
I had thought about this too but I think we're picturing the real F-16 at the wrong size. We're used to tight fitting bubble canopies that have just enough room for your head, where jet fighters have enormous bubbles that go down nearly to the pilot's waist. Likewise, the real F-16 probably has a lot under the pilot's butt where the scaled down version can have you practically sitting on the floor. In any case, it would be interesting to see an overlay of the pilot and passenger on his 60% three-view drawing.
What's been keeping me up at night is how to convert a turbojet (or maybe just gas generator?) into a turbofan. Is there room or any provision to pass the fan shaft down the inside of the turbine shaft or is the solution more... creative? I understand if that's a trade secret for now, it's just been an interesting thought to chew on.
User Lucrum mentioned using a T-58 engine and removing the aft shaft part, would this be the same thing you had on your mind?
https://en.wikipedia.org/wiki/General_Electric_T58
That's one powerful engine, installing a well designed composite fan (like some of those on modern turbofan engines) might show good performance for the desired subsonic speed range.
Acrojet
Jun 6, 2016
53
Gardiner, Maine USA
Man I looked half scaling to keep the weight down for the same motor, and it was just too darn small, especially if I was going to have a "jump-seat" to carry another person. So even 60% was a compromise. Once I looked at 2/3 or even 3/4 scale it became evident that was too big for my little efficient 650-700lb thrust motor to work. That meant going to a Modified GE-T-58, Marbore ll/ V or heaven forbid, the GE J-85/CJ-610. That takes it out of my "wheel house" and puts this into another catagory of jet..... Too heavy, too expensive, too much fuel burn, increased complexity, etc.....
Acrojet
Jun 6, 2016
53
Gardiner, Maine USA
Too big, too heavy and too much work to convert. I don't have the numbers in front of me, but I think that motor weighs roughly 240lbs and burns 125 gal/hr for 800-1000lbs of thrust and my little Tfan weighs roughly 90lbs and burns roughly 45gal/hr....for 650-700lbs of thrust.... No comparison. And if this motor doesn't pan out my model doesn't work..... ;-(
So let's keep our fingers crossed and hope it all works out. The good thing is, the core is already built and running well now, so now it's the fan added and we're in business!
Doggzilla
Jun 2, 2013
2,286
Everywhere USA
The problem with engines is that they are charging prices for hand made parts, yet everything is CNC now. There isnt anything required that cannot be bought off the shelf.
The controls should probably come from turboshafts, as those are the most reliable systems from this power range, but otherwise the parts can be manufactured fairly easily to the standards we are looking for.
The most expensive single tool somebody would need is the balancing machine, which is like $50,000 used, and which needs programming to be able to do whatever specific balancing task is required. These machines are what makes it possible to make small engines and turbochargers. The same machines balance full size turbines. It is the most important tool. They spin the part and then tell you which part needs a little shaved off of it, which allows you to make up for manufacturing imperfections. This dramatically improves the reliability of components, and is basically required.
The parts can be made on CNC or cast, then they are balanced using the balancing machine to make up for any imperfections. This greatly improves reliability and simplicity.
Controls are the most important component and so Im going to say its best to simply buy existing controls that are proven, most likely from turboshafts. Having familiar controls means that mechanics will be more confident working on them and be much more trusting of the engines. If new controls are developed, mechanics may refuse to work on the engines because they are unfamiliar and seem untrustworthy. Using existing proven control equipment will give people much more confidence in the engine, since it will seem much more similar to them. Thats really the only components I really think needs to be bought off the shelf.
Components like combustion chambers can be copied from large turboshafts if required. Since there arent many from pure jet engines.
DangerZone
Sep 5, 2011
2,110
Zagreb HR
Yeah, weight is an issue too, a 50% scale would be better for a single seater but a tandem seater surely allows more comfort at 60%. Did you scale the wings exactly as in the original F-16 design or did you additionally adapt them for better efficiency of the chosen airfoil?
A Czech company was offering some turbojet engine projects a couple of years ago at the Friedrichshafen Expo. An engine looked like a larger size TJ100 of PB, can't remember the name. Anyway, the fuel consumption was horrific, so your figures of 45gal/h at 650-700lbs are really looking good.
Are the fan blades gonna be metal or composite?
nerobro
Nov 6, 2011
1,112
Northern Illinois
Scaling jet engines doesnt' work well. The pressure ratios are pretty low, which leads to really bad fuel economy.
I wonder how much recouperators could affect that..
autoreply
Jul 7, 2009
10,748
Rotterdam, Netherlands
Any hands-on experience with CNC?
A typical blisk for such a tiny engines will have dozens of machining hours. A 5-7 axis CNC machine that can do that doesn't run for less than a few hundred bucks an hour. Plus CAM patterns. By the same multiple blisks are machined, you're tens of thousands of dollars down, and that's just the shaft and compressor/turbine.
Just try finding a machine that can do nickel steels is a major challenge.
A double shaft and it gets way more complicated.
Injectors, ignitors, flame holders, all specialized materials. Tubing for high temps. Bearing for those kind of speeds.
Forget about casting. You have to machine the final part, since casting is about 2 orders of magnitude too rough.
Seals? Biggie too for such an application.
Tolerance stacking gets a major nightmare on such parts.
You need a unique one. An Arduino or such would work, but just finding the sensors is going to be very $$$.
I think doing a small jet engine is incredibly hard. The FJ22 is an amazing achievement, but it's telling that even the best experts couldn't get it to a satisfactory stage after cubic feet of dollars were spent on it.
BoKu
Pundit
Aug 15, 2013
2,596
Western US
...The FJ22 is an amazing achievement, but it's telling that even the best experts couldn't get it to a satisfactory stage after cubic feet of dollars were spent on it.
When I was interviewing with Eclipse, there was a display case showing a bunch of the EJ22 compressor and turbine parts. It was, without exaggeration, an absolute jewel, like something from the watchmaking world championships. I've worked in a Silicon Valley machine shop that specializes in tiny work, and spent a lot of time drilling and tapping holes for #0-80 screws. The EJ22 was like the best of what we'd ever done there, but in materials known for their toughness and intractability.
Of course, what the display didn't show was what we now know to be its "secret sauce;" that it was in fact a three-shaft motor--a feature normally found only in the largest turbofans. So in addition to all the tiny compressor and stator and turbine blades, there are three tiny concentric shafts, and three sets of tiny bearings. And as we also know now, there was very little to it that could be serviced in the field, so every minor failure means a trip back to Merry Olde Englande. After a while, the shipping company just started leaving one of their jets on the ramp outside the Eclipse hangar because they knew there'd be another overnighter to Williams not many days hence. Given that the Eclipse 500 only flew once or twice with those engines, it is probably not too far off to guess that they accumulated 100x the miles being carried to the factory for service than they did actually propelling an airplane.
Thanks, Bob K.
rv6ejguy
Jun 26, 2012
3,749
Calgary, Alberta, Canada
It seems to me a low cost turbofan would be better off using twin centrifugal compressors (staged) rather than multiple axial stages. Way cheaper to machine and assemble and would get you to the 9-10 pressure ratio range. A geared fan would massively increase cost and complexity of design/manufacturing.
No problem to find CNC machines capable of machining nickel alloys. Ceramic tools can wail on Inconel or hard 17-4 at amazing rates, but that machine time will be expensive for sure. Luckily we're talking pretty small parts here for this thrust range so material costs and machining time is lots less than 5000 lb. class engines.
IMO, getting a design that works well and reliably with decent SFC and surge margins will be a lot harder than machining the parts for it.
The key to this whole project is the engine and that's going to be the hardest part too I think.
BoKu
Pundit
Aug 15, 2013
2,596
Western US
It seems to me a low cost turbofan would be better off using twin centrifugal compressors (staged) rather than multiple axial stages. Way cheaper to machine and assemble and would get you to the 9-10 pressure ratio range...
I've wondered about that myself. I think that the big challenge of serial centrifugal compressors is the topology of delivering air from the output of one stage to the eye of the next. I'd bet that there would be a lot of friction and inertia losses from the convoluted ducting.
nerobro
Nov 6, 2011
1,112
Northern Illinois
There are several designs on the market that use a few stages of axial fans leading to a centrifugal compressor. Having the off axis burner can makes it more likely you can make a recouperator work.
Battler Britton
Nov 14, 2015
518
Montpellier,LFNG (Candillargues)
Jay,
Don't worry. Worrying can stress you out, which can lead to obesity and can give you a heart attack....
So.... You'd be too big to fit, or worst case, dead! ;-)
But seriously, as mentioned before, it will be tight, but not any worse than a BD-5 (which I fly and fit into, consiquently)
The pilot will sit almost on the floor of the cockpit area and his feet will go way up to the front of the pointy nose... Almost.
I'm staying with the "single place" canopy lines just because they look better, but it will be larger to accommodate both occupants. The canopy might be the only thing that looks noticeably "off-scale" to the naked eye. It will still look good, and the rest of the ac will be almost spot on with a few tweaks here and there. Also a 30degree recline is pretty aggressive already and that will work well.
Scale gear already to be machined, exactly to scale.... That was a real stumbling block until I got the idea to contact one of the companies that supplies scaled machined gear for the RC community and they were gracious enough to scale-up one of theirs and even powder coat it white for me. It will come with both nose and main gear and include the retract mechanism an associated actuators, which I may make pneumatic along with the air brakes. Cool stuff.
Peter
Some pictures of , maybe a smaller ,but quite similar and 2 seats aircraft. JUST with a 200 hp Lyco
I saw quite often this " very" small plane, and the canopy could be like a 60% F16, but is still big inside
http://cc02aircraft.free.fr/fr/index.php?option=com_content&view=article&id=52&Itemid=57
The design of the DC-02 began in the 90 A model 1 / 13th was tested in the wind tunnel at the IUT of Ville d'Avray to test the longitudinal and lateral stability, including on the back. Indeed, it is intended to do real aerobatics.
So,if the gear can support 3.5G, the aircraft is scheduled for the 9 + / -9G.
about range, CC02 has 4 tanks (in the wings) or 150 liters in total, which makes 3 hours playing at 185 knots, 342 kmh (with 30 minutes of reserve) or maximum range of 1000 km.
Speed: 85 knots, 157 kmh
Max. 300 knots, 555 kmh
Approach speed: 110 knots, 200 kmh
Final speed: 100 knots, 185 kmh
economic cruising speed with the first fixed pitch propeller: 155 knots, 287 kmh
Lycoming 200 hp.
The plane was built in the pilot's garage - owner - designer. Then it was completed in the RSA shed Nangis.
The first flight took place in 2007 in the field of Nangis les Loges (LFAI) (France, near Paris).
Doggzilla
Jun 2, 2013
2,286
Everywhere USA
Williams has been doing this since the 1970s with the FJ-33, well before CNC or laser balancing equipment existed. It should be relatives straightforward to produce an engine with the same efficiency using off the shelf controls and CNC parts. The average machine shop actually exceeds most aerospace companies back when this stuff came out.
Doggzilla
Jun 2, 2013
2,286
Everywhere USA
WR24-7-2
For those that are interested in small gas turbine technology, the above link is an interesting one to see how a small gas turbine engine is constructed, albeit an older design.
This is actually the generation before the FJ engines, which are 24-40 years old. The only reason its so simple is because its a one use engine. Its for a cruise missile. Williams also makes some for Tomahawk cruise missiles, but most of that stuff is pretty hush hush.
rv6ejguy
Jun 26, 2012
3,749
CNC was actually around in the early 1960s. The aerospace industry was using CNC machines extensively by the mid to late 1960s... Giddings and Lewis, Sunstrand and Cincinnati were the main suppliers at that time.
McDonnell Douglas had 80 CNC machines in 1969.
rv6ejguy
Jun 26, 2012
3,749
Yes, you need a lot of funky tubes to do that but 2 centrifugal stages gives you a decently high PR which would require 4-5 times as many axial stages. 3D printing of the "funky tubes" might be a big time saver. Axial is elegant and small diameter, centrifugal is cheap.
