Not sure if this is the place for this question, if not, please move it to the appropriate forum.
Does anyone here have an aircraft that has turnbuckles on some/any of the control cables and the turnbuckles are routinely ( or somewhat regularly ) 'disassembled' and 'reassembled' for any reason ( moving / maintaining the aircraft, removing wings etc. ) ??
If so, I suspect ( and hope ) that you keep the turnbuckles safety wired and if you do, do you simply re-wire them each time they are reassembled or -
Is there some trick or 'neat gadget' or 'little known procedure' that would simplify or eliminate the removal/re-installation of the safety wire over and over ??
In my case there are only two to deal with but every time I look at them, I think , 'there HAS to be a simpler way of doing this repeatedly' !!!!
Thanks in Advance for any idea suggestion !
