RV3 Tailwheel
ddsrph
Jul 28, 2010
32
Tullahoma, Tenn
I wanted to mod my rv3 tailwheel to fix the problem of the low to ground tailspring. Rather than trying to cut and modify the original tailspring, I decided to go this route. Working great so far and I can convert back to original tailwheel in about 15 minutes.
fly2kads
Jan 2, 2010
1,570
Justin, TX
Do you have a "before" pic? For those of us not versed in RV lore, what changed?
ddsrph
Jul 28, 2010
32
Tullahoma, Tenn
The original vans rv3 tailwheel and fork pivots on the down turned portion of the tailspring but sits so low to ground the end of tailspring just clears the ground by about one inch. Some RV 3's have caught this on rough Tarmac and damaged the airframe where the tailspring attaches. To correct problem most replace tailspring with a straight rod and new tailwheel assembly. Sometimes it is difficult to remove old tailspring and also difficult to drill new one correctly. I have a small mill/lathe from HF and made a new adapter from 6061 to fit a tail fork from aviation products and a new light weight wheel from Van's. I didn't take a before photo, but should have.
JM
7,877
JM
Tarmac, Do you mean Ramp? Most ramps are concrete.
http://aviationglossary.com/tarmac/
Rockiedog2
Dec 11, 2012
2,333
Tarmac. That always annoys me when they call it that Pops. It's ramp.
Toobuilder
Jan 19, 2010
4,667
Mojave, Ca
I would anticipate some significant wear on the "kickstand" forward brace if it is not secured to the tailspring. Flex in the rod aft of the contact point is going to cause the brace to fret against the spring. Throw some grit and oil in there and you may end up turning both parts into scrap in short order. Something to keep an eye on.
7,877
Same here. When I hear someone calling a ramp a tarmac , I know they are a new to the aviation world. That is why I included a link to an aviation glossary. Maybe we can get it turned around to the correct word.
But some people like to call a ramp a tarmac because it's so "European", and not American.
  • Like
Reactions: BJC
Mcmark
Sep 24, 2013
326
Owings, MD
Will it cause issues with reduced AoA in the flare? Looks to me like it is roughly 3-4" taller from original design. TooB has good points also...
Rockiedog2
Dec 11, 2012
2,333
I'm good with apron. We called it apron and ramp in the military.
it's the media that's most annoying when they say tarmac. they generally don't know what the hell they're talking about.
I may have an attitude about those people. yeah I think so.
7,877
Same here. Low lifes to the 10th degree.
10,811
There are other areas where the media has shown that they don't know what he hell they are talking about. But, since they are paid to talk, they talk. Doesn't mean that we must listen to them.
Pops, I appreciate your efeots to educate the public on the correct terminology.
ddsrph
Jul 28, 2010
32
Tullahoma, Tenn
All the rv3 tailwheel mods I have seen raise the tail about the same amount. I do all wheel landings and keep tail up as long as possible, depending on cross winds. The point about wear on the anti rotation/tailspring area is a good point and may require attention and possible change in design. When I get time I may just remove the old tailspring and replace with the new SS one I have from aircraft products. I have heard of problems of removing old tailspring and trying to drill new one to fit. I am so busy now building a new house I didn't want to start something I don't have time to finish.
Thanks
JM
13,302
Pops, I appreciate your efforts to educate the public on the correct terminology.
I thought this thread was about RV-3 tailwheels. We should limit our discussion to what the media calls the RV-3 tailwheel (Tarmac Roller?). ;)
