running cylinders off rear location of full case?
Discussion in 'Half VW' started by Rob40, May 10, 2017.
  1. May 11, 2017 #21
    revkev6
    revkev6
    revkev6
    Mar 9, 2010
    425
    91
    massachusetts
    I would venture to guess that pops knows more about building VW engines for aircraft than anyone here... show him a little respect... ;)
    there are three bearings that support the crank in a VW... on of which is in the middle between the cylinders.. all you have to do is find a picture of a case to see
  2. May 11, 2017 #22
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    OOPS! :emb:
    cheapracer likes this.
  3. May 11, 2017 #23
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    By the way, has anyone thought of calling Great Plains and asking them the question?
  4. May 11, 2017 #24
    7,404
    6,366
    I have weighed VW long blocks ( no accessories, no intakes, exhaust, prop hub, etc) in 1200 cc, 1600 cc, 1835 cc, 1914 cc and 2180. They all weigh 116 lbs except for the 2180 and its 118 lbs due to the larger stroker crankshaft. The thickest cyl walls is in the 1200 cc, 77 mm dia piston.
    The lightest engine installation that I know is the engine in my SSSC. Firewall forward, running and flying, with the prop, engine, intakes and carb and airbox, exhaust system with carb heat muff, Slick mag and mag drive, oil cooler and hoses, engine baffling and 4130 tube engine mount is 141 lbs. I could make it a little lighter because my stainless steel exhaust tubing and intake tubing is excessively thick.
    I have been slowly putting together a 2180 flywheel drive engine and thinking about a Carbon Fiber intakes with a short metal section at the head and CF baffling and oil cool shroud, and the correct thickness exhaust pipes.
    I believe I can get a firewall forward weight of about 138 lbs and that is without using the aluminum jugs that save 5 lbs.
    I have been thinking of building another version of the SSSC but getting serious in getting the EW as low as possible with the light 2180cc flywheel drive engine.
    I can use the first wings that I built for the SSSC with the small wing fuel tanks of 8 gal total. But not sure if I would want to use then, might go with a different airfoil .
  5. May 12, 2017 #25
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,707
    4,136
    Australian
    Thanks Pops, appreciate your time.
    Oh sure, and next you'll be expecting us to read instruction manuals!
  6. May 12, 2017 #26
    12,512
    2,534
    If the prop is mounted on the flywheel end of the case then the crank could be cut off and a straight prop shaft fitted out to the prop.
    It would be a bunch of work just to eliminate the weight of two throws.
  7. May 13, 2017 #27
    Bill-Higdon
    Bill-Higdon
    Bill-Higdon
    Feb 7, 2011
    477
    145
    Salem, Oregon, USA
    The problem with this is the cam drive at the other end of the case
  8. May 13, 2017 #28
    7,404
    6,366
    And the oil pump is driven off the cam.
  9. May 13, 2017 #29
    12,512
    2,534
    What problem? The cam is either cut off or not, doesn't matter. The prop mounts on flywheel end and the two cylinders are on the pulley/cam gear end which is now near the firewall. So a long pointed cowl can be fitted.
    sotaro likes this.
  10. May 13, 2017 #30
    N8053H
    N8053H
    N8053H
    Jan 31, 2013
    2,521
    442
    I believe the dude is Leonard Milholand who built the Legal Eagle who makes a full case 1/2 vw.
    Tony
  11. May 13, 2017 #31
    7,404
    6,366
    I understand you now. So it's just a full case 1/2 VW but the prop driven off the flying wheel end. You can also cut the large flange of the case off the flywheel end for even more pointed cowl.
    sotaro and BBerson like this.
  12. May 13, 2017 #32
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    Yes, and Great Plains Aircraft sells them, or at least parts to build one.
  13. Sep 16, 2018 #33
    sotaro
    sotaro
    sotaro
    Feb 27, 2011
    125
    16
    San Francisco
    So, if you cut the crank just forward of the center main bearing, the prop shaft replacing the rest of the crank (2 throws) would be supported by the center and flywheel end main bearings. Would this be a substantial improvement on the ability of the engine to withstand gyroscopic propeller forces being transmitted to the crank?
  14. Sep 16, 2018 #34
    12,512
    2,534
    The stock crank is stiff enough as is for four cylinders. Certainly strong enough for the 2 cylinder sized small prop.
    Would be tricky welding a straight shaft anyway.
    sotaro likes this.
  15. Sep 16, 2018 #35
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,123
    410
    Gustavus, AK
    I may be understanding the question differently. The way instead it, have wants to do a flywheel drive half VW, which would be fine, except that the oil pump, distributor drive, etc. Is in the other end. Might be tricky to do a cut case that way.
  16. Sep 16, 2018 #36
    12,512
    2,534
    The OP wanted to go with full case.
    He got the answer in post 7-8.
    Other comments are various alternate ideas to cut weight off the crank.
  17. Sep 16, 2018 #37
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,123
    410
    Gustavus, AK
    Ah. My bad.
