don january
In the picture you can see the gussets at the end of each rib and they are higher stepped then the plain of the rib. I can find no info on the plans if the rib need to be capped with say balsa to even out the plain or does a person just feather sand the gussets and cover and stitch? Any input from someone that has done this sure would be helpful. Thanks Don
