Rotax C redrive. 3:1, maiting to motor 40kW/60HP is it OK ??
Frank Downunder
Sep 2, 2019
4
Hi im looking to mate Rotax C redrive 3:1 to BMW R1100 (60kW/80KW @ 7250RPM) oilhead boxer motor, what RPM/Tourque limits on the imput side, ok with supplied propellor weight & momentum limits previous life lived on Rotax 503
Cheers
Frank
n3puppy
Jun 25, 2019
218
Can't say for sure for RotaxSpec. But Simonini says their version of the "C" is good for 150hp FE8E3F95-D5AA-40B1-AE15-4577DB284D6C.png
Frank Downunder
Sep 2, 2019
4
Will you be using the clutch coupling, or the Hardy Disk coupling? C boxes have been mated to BMW boxers in the past.
will be using the rubber doughnut coupling, clutch coupling came out on E gearbox the one with ther starter motor, would love got own one if can
