Rohr 2-173
Discussion in 'Hangar Flying' started by Bill-Higdon, Feb 2, 2020.
  1. Feb 2, 2020 #1
    Bill-Higdon
    Bill-Higdon
    Bill-Higdon
    Feb 7, 2011
    497
    154
    Salem, Oregon, USA
    This you tube video has the Rohr 2-175, sadly no actual inflight video
    Curt Curtis likes this.
  2. Feb 4, 2020 #2
    vhhjr
    vhhjr
    vhhjr
    Jun 29, 2003
    62
    69
    I read a flight report and this aircraft apparently flew quite well. Unfortunately, if I remember correctly, Rohr decided not to get into the airplane business and destroyed the air frame to avoid liability issues. Sad, but we all know the lawyers prevail.
  3. Feb 4, 2020 #3
    6,599
    5,380
    Wow, look at that step/droop in the leading edge just outboard of the main gear!
    Riggerrob likes this.
  4. Feb 4, 2020 #4
    10,242
    6,964
    See . Flights start about 18 minutes in.
    bmcj and cheapracer like this.
  5. Feb 4, 2020 #5
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
  6. Feb 4, 2020 #6
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,261
    372
    Canada
    That sort of dogs' tooth notch is quite common on swept wings because it reduces spanwise airflow along the leading edge. It reduces the risk of a wing root stall continuing all the way out to wing tips. Because wing tips are behind the centre of gravity, they produce a positive pitching moment (nose down) that helps with stall recovery.
    Early Mig fighter jets solved problems with pre-mature tip stall by installing wing fences.
    Many delta wing fighters (e.g. Mirage) have dogs' teeth.
    Burt Rutan solved the problem with tiny pylons hanging below the rear/main leading edges of his Long Eze canard.
    Velocity added similar tiny pylons to rear/main wings of their Rutan-like canard after a prototype crashed in a flat, stalled attitude.
  7. Feb 4, 2020 #7
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,261
    372
    Canada
    Dear moderators,
    Please merge this thread with the other thread about small deltas: Dyke Delta, Delta Kitten, Facetmobile, Hustler, Verhees Delta, etc.
  8. Feb 5, 2020 #8
    12,669
    2,591
    From behind, that Rohr looks like the Space Shuttle orbiter.
  9. Feb 5, 2020 #9
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,428
    348
    YMM
    If it was to be merged there's a few already on the Rohr 2-175
    This would be an absolute winner as a kit :)
  10. Feb 5, 2020 #10
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
    No way, this is a unique, stand alone aircraft. It shares very little in common with those others, other than being a delta planform.
    How about we throw all 3 axis aircraft in together instead? Yeah, thought so.
    One very unique feature, is that the fan was designed to use engines spinning at 4000 rpm. That opens the door for a large range of today's automotive engines direct drive (read cheap) that weren't available in the early 1970s.
    I have a simple 3D of the Rohr, and a few of my own 'easy to construct' iterations...
    I have also found Don Westergren, part designer and test pilot of it, hoping to ask him some questions.
    Hephaestus and bmcj like this.
  11. Feb 5, 2020 #11
    vhhjr
    vhhjr
    vhhjr
    Jun 29, 2003
    62
    69
    This looks like the "Facetmobile" version of the Rohr. Aerodynamically, it's petty much a flying wing as there's no horizontal stabilizer. It will be interesting to hear what Westergren has to say about the aircraft.
    cheapracer likes this.
  12. Feb 5, 2020 #12
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
    You see a Facetmobile?
    Something wrong with your computer screen, this is what I see ..
    bmcj likes this.
  13. Feb 5, 2020 #13
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,428
    348
    YMM
    It's one of my favorite aircraft. It looks modern. The tandem would be awesome as long as you kick up the rear seat a smidge for visibility.
    A single seat with a Honda would be pretty quick and easy to build it would appear.
    I've been trying to get my hands on the for Rohr book for a while. Don W is over on rcgroups if I recall (there is a foamie version there and he weighed in on some of his impressions of the original)
    Don't forget to check out the float plane tests.
  14. Feb 5, 2020 #14
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
    You'll never get a single seater out of me, just no market really.
    ? Don't understand.
  15. Feb 5, 2020 #15
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,428
    348
    YMM
    There were models tested with skis in floatplane style. No joke.
  16. Feb 5, 2020 #16
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,428
    348
    YMM
    Some of the wierd tidbits you get out of reading about the Rohr
    Wing was made as green layups of the exterior shell - then they added EPS foam and steamed to get pressure/heat for final cure and to add the core. No spar at all.
    I've often eyeballed it as a great scenario for a homebuilder. Cut the wing, and vstab - Rutan style wet layups. A welded steel roll cage structure (go a 40g top fuel dragster style safety cage and engine mount) drop on 2/ 3 molded composite pieces to skin the fuselage. Duct takes a bit more skill to cut but easily done in a CNC Hotwire
    The Delta gives it the area so it's like a practical bd5. Other than the approach/flare being 'different' it was apparently quite benign on handling. It was designed to compete with the 150/152...
    It could be a quite safe very quick built kit.
    Although I really do like the idea of it with a 583/ivoprop as a single seat quick/easy project.
  17. Feb 5, 2020 #17
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
    Only aluminium for me.
    Got to figure this one out, worth doing as it solves the engine issue, and that's half the plane.
  18. Feb 5, 2020 #18
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,428
    348
    YMM
    To me aluminum just makes the parts count and build time soar...
    Not volunteering - but it would be interesting to work out the design as 'open source' - work out the details/loads - aluminum, composite and wood version of the same basic airframe. Builders could pick and choose which version they preferred - but keeping some of the oddball pieces backwards compatible - like the duct, the cowling, canopy & frame etc.
  19. Feb 5, 2020 #19
    Blackhawk
    Blackhawk
    Blackhawk
    Apr 18, 2008
    148
    45
    AUSTRALIA
    Back in 2011, I looked into redesigning the Rohr for our Australian RAAus weight category
    This was my idea
    Vigilant1, cheapracer and Hephaestus like this.
  20. Feb 6, 2020 #20
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,838
    4,327
    Australian
    Well I am proving at the moment that's no where near as bad as some imagine, and I can't change that I am comfortable with metals, and that everything for metal working is within a stone's throw from me.
    It would appear to be a matter of fact that Americans, i.e. the world's largest market, are most comfortable with metal kit planes as well.
