Riveted plywood to aluminum?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by buzzypeterson, May 7, 2015.
  1. May 7, 2015 #1
    buzzypeterson
    buzzypeterson
    buzzypeterson
    Sep 23, 2010
    160
    24
    Wausau, WI USA
    How about the idea of riveting a plywood wing skin to aluminum wing ribs? On a fabric covered homebuilt.
  2. May 7, 2015 #2
    12,060
    3,477
    Why?
    SVSUSteve, akwrencher and Lucrum like this.
  3. May 7, 2015 #3
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,916
    1,820
    Upper midwest in a house
    More weight?
    pictsidhe, SVSUSteve and JamesG like this.
  4. May 7, 2015 #4
    buzzypeterson
    buzzypeterson
    buzzypeterson
    Sep 23, 2010
    160
    24
    Wausau, WI USA
    Just because. Not for sure heavier. You can get ply that weighs less than heavy fabric.
  5. May 8, 2015 #5
    JamesG
    JamesG
    JamesG
    Feb 10, 2011
    2,408
    754
    Uh.... no. unless you are planning on using wool blankets.
    SVSUSteve likes this.
  6. May 8, 2015 #6
    Super Moderator Staff Member
    Apr 4, 2007
    8,847
    3,191
    Any plywood lighter than polyester fabric is going to be a lot weaker than the fabric. Also the plywood won't give like fabric as the structure flexes. Repairs would be more difficult, too.
  7. May 8, 2015 #7
    don january
    don january
    don january
    Feb 11, 2015
    2,723
    1,166
    Midwest
    Wy not just rivot alum. skin to the alum ribs and be done with it???
  8. May 8, 2015 #8
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,488
    3,215
    Western US
    I think that you'll find that the allowable bearing stress of the plywood is so low that, unless you use Rivets Of Unusual Size (ROUS), you will see fretting and fastener tear-out at rather low load factors.
    Thanks, Bob K.
  9. May 8, 2015 #9
    7,351
    2,118
    Plywood would be better buckling wise than aluminium skins. Might be good as a monocoque. As Boku said, it's bearing stress isn't great. Instead of big rivets, use a zillion of them, or rivet and glue. Fun if repairs needed.
    don january likes this.
  10. May 8, 2015 #10
    JamesG
    JamesG
    JamesG
    Feb 10, 2011
    2,408
    754
    It would make it a semi-monocoque, but doesn't really play to the strengths of either.
  11. May 8, 2015 #11
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    Metal and wood have been mixed in many weird and wonderful ways and in the case of the DeHavilland Hornet in a very successful way. Using the strengths of each to their best advantage. But they had a very clever engineering department behind them and chemists working on glues (Redux) and lots and lots of testing. Doing it the homemade way might be less successful. If you look at the design as a mainly wooden structure with metal reinforcement, you might be more successful.
    ultralajt and cheapracer like this.
  12. May 14, 2015 #12
    buzzypeterson
    buzzypeterson
    buzzypeterson
    Sep 23, 2010
    160
    24
    Wausau, WI USA
    I remember in my minimax wiggling the wing on a preflight and noticing the cabin wasn't moving with the wing. Turns out the plywood and the metal glue joint would not hold. That gave me the idea of riveting wood, there was a very slick looking T tail single seat light 2 stroke powered plane with a plywood skin. It was glued to aluminum. Anyway I'm just brainstorming.
  13. May 14, 2015 #13
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    What came un-glued on your MiniMax that allowed the wing to move?
  14. May 14, 2015 #14
    Jon Ferguson
    Jon Ferguson
    Jon Ferguson
    Dec 15, 2011
    827
    382
    Harpers Ferry, WV
    Rivets of unusual size... I don't think they exist...
    akwrencher likes this.
  15. May 20, 2015 #15
    skeeter_ca
    skeeter_ca
    skeeter_ca
    Jun 29, 2005
    1,027
    50
    Yucaipa, Ca
    :roll::roll::roll::roll:
  16. May 20, 2015 #16
    Autodidact
    Autodidact
    Autodidact
    Oct 21, 2009
    4,513
    799
    Oklahoma
    I've thought of this, too. But really only as a non structural wing leading edge, for example. Look at the Ercoupe wing structure; the torsion and drag loads are reacted by the warren truss formed by the ribs and spars. Now replace the partial D-tube leading edge with plywood and that's what I was thinking basically. Metal dents easily; the wood either breaks or doesn't, and it can be cut out and a patch glued in. I haven't done any weight studies, so I don't know if it is workable for a 103, for example.
  17. May 20, 2015 #17
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    I think the leading edge on the Ercoupe is taking more than its fair share of the torsion loads; it isn't just a fairing. I agree , for a non-structural leading edge, there are better materials than thin metal, but not in a case like the Ercoupe.
  18. May 20, 2015 #18
    Autodidact
    Autodidact
    Autodidact
    Oct 21, 2009
    4,513
    799
    Oklahoma
    Then I don't understand how; it is not a complete D-tube and doesn't extend back to the spar on the lower surface. Can that react to torsion any better than a bent angle? (It would help with the anti-drag loads, though...)
  19. May 21, 2015 #19
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,927
    977
    Grand Junction, Colorado
    Sure there are. We call them "drive nails" and in my former line of work we used them to attach posts to concrete patio slabs. The most common size I used is 1/4" diameter X 2" long. They look just like big pop rivets. We set them with a 14 oz framing hammer :gig: If you need something much bigger expanding bolts are better
