"A good row of structural rivets has been the standard for years."
True, but a riveted joint will always be a percentage of the strength of the material being riveted. If you want/need a stronger joint you have to use stronger material. Using adhesives or a combination of rivets and adhesives you should be able to obtain a larger percentage of the joined materials strength in the joint. It would seem that adhesives offer the opportunity to exceed the joined material's strength in certain aspects (which poses problem's as well...).
" Are you considering the -4? It would make a fine choice, IMHO."
If I won the lottery I'd buy an Extra... I have Pitts plans, but I'm not willing to commit to a single seat plane. I've talked to the Laser people about their 2 place. It's a tube fuselage with wood wings, as are the Staudacher, Panzl and Rhin designs, and all well north of the $100K mark. Given that the Sukuoi's and Zlin's are or have been sheet metal designs, I thought I would see what I could come up with. So, since the RV-4 has been used in IAC competition and is 2 place I thought I would start there. The main problems are the low Va, which is a result of the low Vs and the modest load rating, and the low Vne, which is apparently flutter limited. At this point the RV-4 is just a point of entry, a known quantity to run analysis on. It may turn out that the -4 needs very little, and the modifications relatively minor... Or not...
Please don't think I'm knocking the RV-4, or think that I know more than R.V., it's just that you can't fly it like an Extra in it's present form.
" Getting parts more or less prefabbed is hard to beat!"
Agreed, provided they are the 'right' parts...
