Registering “Plans Built” aircraft in Canada.
fusionfab
May 16, 2012
88
southern ontario canada
Hey everyone,
I have been trying to find these answers for a couple days on Transport Canada sites as well as general online searches with little to no luck.
I’ve only ever registered ultralight aircrafts that were built by the manufacturers and I only restored them. So they already came with previous registrations and had serial numbers. But if I’m to build a “plans built” aircraft next that doesn’t come with a serial number can it still be registered? I’m curious to know this for both Ultralight as well as Amateur Built Aircraft.
thanks in advance.
Ratterrier
Apr 12, 2020
20
For a basic ultralight it is very easy. Make sure it qualifies, then build it apply for a registration mark. (as the manufacturer you get to assign it a serial # 0001 is nice) Then you can register it. It is quite easy.
If you wish to legally carry passengers or build something that doesn't qualify as a basic ultra light it gets a lot more expensive and complicated. Before you start must send a letter of intent to MD-RA Inspection Service Welcome | Bienvenue - MD-RA Inspection Service, RM-AL Service d'inspection You will then need to have it inspected at certain points in the construction depending on build (box spar ect.) MD-RA is not Transport Canada. The inspections can be rather pricey depending where you live, repeat inspections can add up. The inspectors I think are volunteers, but not MD-RA itself. I just went through the process for Basic Ultralight last year and it was quite painless. Any other questions I will do my best to answer. There is a lot of miss information out there. Larry
Ratterrier
Apr 12, 2020
20
I forgot to mention, with Basic Ultralight there are no inspections and you don't have to tell anyone you are building it. Just build it and register. A lot of freedom but obviously it is imperative to find some trusted to look over ones shoulder. Things can be missed!
fusionfab
May 16, 2012
88
Thank you very much for the info, I checked out the website you attached and gave their office a call. I spoke to someone who was also able assist. I’m just now waiting for an inspector to get back to me.
As I mentioned, in the past, I’ve only ever registered Basic Ultralight. My avid heavy hauler I wanted to register as AULA but I think previously went down this path and was given some inspection quotes. Being to eager to fly it I just went ahead as basic.
But now I am deciding to either start a Bearhawk 4 place registering into amateur built or a larger ultralight to register into AULA.
But...If going ultralight again, I am considering taking a few different designs and combining them for a one-off design. But I’d rather know ahead of time if registering a Frankenstein is even possible.
thanks again.
