Redrive. Any reviews???
rv6ejguy
Jun 26, 2012
3,749
Calgary, Alberta, Canada
The price is certainly fair compared to aviation redrives and it probably has a lot more hours on it than many other designs. Has a damper and looks dirt simple.
Streffpilot
Jul 12, 2011
318
Mukwonago, WI
Any comments on the design?? It will be used in a pusher, so I think the bearings are all good. But any other thoughts or concerns???
blainepga
May 20, 2011
69
Queen Creek, AZ 85142
I have looked into it. It can be used with any Chevy big/small block v8 or 90 degree v6. It has 2.0 reduction ratio and has had no failures in twenty five years of use on airboats. They get more use than any airplane. It is a very stout unit with a reverse rotation. No different than using a low time certified reverse companion from a twin. They're only $2195 and you supply the flex plate for attachment to the engine. They will attach their resonance absorbing coupler to the flex plate. I am using the Ecotec 2.0L supercharged engine and am fabricating and adaptor plate for this combination. My PSRU is on the way. I'll have pictures of my adaptor plate and the PSRU attached to my engine in the cradle I am building with a mockup of my firewall so that I can build my engine mount. Blaine Anderson
Goatherder
Nov 13, 2013
20
Olympia WA / Itajai, Brasil
Rotator 1.53:1 gearbox from Panther Airboats. $2650+shpg. Hundreds in service, very reliable, 1000hp rating, about 70 lbs w/ soft drive coupling. 12" long, C-to-C crank-propshaft is about 5", Prop flange is LXL (4.75" w/ 1/2" bolts). Buick/Olds/Pontiac + Chevy bolt pattern. Don't tell 'em its for an airplane.
FYI - amongst the airboat crowd these Rotators have a MUCH better reputation that the Precision gear drive described above, and are available in many different ratios.
602290_10200797846488617_708882040_n.jpg935510_10200797845848601_1656000648_n.jpg1395191_10200797846848626_1664424857_n.jpg
