Raptor Composite Aircraft
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Dexacare, Mar 28, 2016.
  1. Jun 23, 2019 #821
    Kyle Boatright
    Kyle Boatright
    Kyle Boatright
    Nov 12, 2012
    708
    354
    Marietta, GA
    Lesson 1: How to make the CG acceptable when your rear mounted propulsion system didn't meet weight goals.
  2. Jun 23, 2019 #822
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    Once again, not to defend anything going on with this project, but many side-by side canard aircraft need ballast in the nose when flying solo. In my COZY MKIV, I carry 50 lb. of ballast in the nose when solo, and take it all out when I have a front seat passenger that weighs more than 100 lb. Velocities generally don't need ballast (but also generally fly more forward within their CG range).
    It's not at all surprising that the Raptor would need nose ballast for flight testing (when solo) and to ensure that the CG is mid to forward within the CG range for the start of testing. And since it weighs approximately 2.75X what my COZY MKIV weighs empty, it's not surprising that it would need ~2X times the ballast. In fact, since the 50 lb. I use gets me exactly on the rear CG limit when solo, if I wanted to be at 1/3 of the CG range, I'd need a LOT more. So 100 lb. isn't out of line, as a reality check here.
    It would be very interesting to see the estimate of CG range for the Raptor, as well as to see what the W&B range looks like with the current engine as well as with a much lighter one. It MIGHT be the case that the empty CG would be so far forward with, say, an O-540 or O-550 that the maximum front seat weight would be minimal, and you couldn't even take 2 people in the front. But without seeing the W&B calcs (as well as the location of the AC), it's all guessing.
  3. Jun 23, 2019 #823
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    Calgary, Alberta, Canada
    I've learned a lot about canard characteristics from your posts in this thread Marc. Thanks. Many things never even occurred to me before. I'm curious as to how wide the C of G envelope is in something like a Cozy or Velocity compared to something like an RV-10?
    TarDevil likes this.
  4. Jun 23, 2019 #824
    flyboy2160
    flyboy2160
    flyboy2160
    May 25, 2014
    168
    85
    california, USA
    We need a poll: Is this thread The Most Entertaining Thread on HBA?
  5. Jun 23, 2019 #825
    8,877
    5,729
    Only if you consider watching a train wreck in slow motion entertaining. To me the whole thing is just sad.
    wsimpso1, Topaz, pictsidhe and 3 others like this.
  6. Jun 23, 2019 #826
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    You make the assumption that I'm not making things up as I go along :). But thanks.
    So I know diddly about RV-10's, but a perusal of this POH:
    shows a CG range of about 8" (108" to 116"). Canards tend to have smaller CG ranges than conventional aircraft. A COZY MKIV has a CG range of 97.5" to 102", or about 4.5". Long-EZ's have a range of 97" to 103" (6" total). On the other hand, a Velocity XL (similar in size to the RV-10 and Raptor):
    has a CG range of 127" to 134" - about 7", so not substantially different than the RV-10.
    The difference with canards is that the front seats are not just slightly forward of the CG range - they tend to be VERY far forward of the CG range, so an extra person in the front changes the CG position a lot (although less for the heavier canards, like the Velocity XL). With an RV-10, adding baggage or people in the rear seat will substantially move the CG aft, whereas adding baggage or people to the back of a 4-seat canard hardly moves the CG at all.
    I never worry about CG with respect to what/who I throw in the back seat - only that the person next to me in the front weighs 100 lb. or more so that I can remove my nose ballast, or that they're less than 280 lb, so I'm not forward of my forward CG limit. Happily, the largest person I can FIT in the front seat with me is about 240 lb. (without liquifying them and pouring them into the plane).
    On the COZY MKIV (and Long-EZ, and I presume the Velocity as well), rear CG limit is more limited by deep stall considerations than stability considerations - I've flown my plane at 103" (1" aft of the rear limit) and it's not even close to being only neutrally stable. But it MIGHT be susceptible to deep stall at that location.
    David Lewis and rv6ejguy like this.
  7. Jun 23, 2019 #827
    8,877
    5,729
    My understanding is that the liquifying part of that is an irreversible process.
    ScaleBirdsPaul and rv6ejguy like this.
  8. Jun 23, 2019 #828
    mm4440
    mm4440
    mm4440
    Jan 14, 2012
    99
    17
    LA area, CA
    Sometimes it takes more than magic. In engineering it is said, " All it takes is time and money, possibly in infinite amounts. Prayer couldn't hurt.
    Topaz likes this.
  9. Jun 23, 2019 #829
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    Well, I can say that no-one has ever requested it in order to get a ride.
    rv6ejguy likes this.
  10. Jun 23, 2019 #830
    Deuelly
    Deuelly
    Deuelly
    Nov 6, 2012
    82
    80
    Marshall, MN
    And it makes the rudder pedals very slippery.
    Brandon
  11. Jun 23, 2019 #831
    5,874
    1,492
    So, I just need to mumble a few incantations, and anything is possible?
    Why the hell is that in none of my reference books?
  12. Jun 23, 2019 #832
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    I don't know where you went to engineering school, but at MIT, there was an engineering course (Mechanical Engineering 2.47) titled "Spells, Incantations and Sacrifices - Advanced" (strangely, there was no introductory course in this area - go figure). The textbook used (IIRC) was Hermschmitdt's "Goats, Chickens and Virgins: a Sacrificial User's Manual". The course covered all means of effecting the supernatural when designing mechanical, aeronautical, nuclear, civil, or electrical engineering systems. Since software is always supernatural and non-deterministic by nature, there was no need to cover it in this course. It was numbered 2.47 because it was, in truth, a thermodynamics course - all magic must at its core violate the laws of thermodynamics (something Hermschmidt makes abundantly clear in Chapter 3 - Basis of Events).
    Obviously, it's not as simple as just "mumble a few incantations" (I assume you were being rhetorical), else why would Hogwarts, et. al. be necessary - everyone could do it. You have to be trained. It's certainly possible to be autodidactic in this area, but it's rare.
    I would have assumed that this would be covered at all engineering schools, no? That's what happens when you get both your degrees from the same institution - you don't get a view of what goes on in the wider world... although maybe times have changed since I was graduated in 1981.
    lvaero, pictsidhe, rv6ejguy and 2 others like this.
  13. Jun 23, 2019 #833
    8,877
    5,729
    At Georgia Tech, we did not sacrifice virgins.
    rv6ejguy, gtae07 and Vigilant1 like this.
  14. Jun 23, 2019 #834
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    Sure you did. You just used different techniques. At MIT, well... let's just say social ineptness was taken to the extreme.
    bmcj and pictsidhe like this.
  15. Jun 23, 2019 #835
    TarDevil
    TarDevil
    TarDevil
    Jun 30, 2010
    247
    115
    Coastal North Carolina/USA
    I'm suddenly in an alternate world.
    Perhaps there is a way the Raptor will, indeed, fly
  16. Jun 23, 2019 #836
    Kyle Boatright
    Kyle Boatright
    Kyle Boatright
    Nov 12, 2012
    708
    354
    Marietta, GA
    Must not respond to post... Must not respond to post...
    wsimpso1, bmcj, gtae07 and 1 other person like this.
  17. Jun 24, 2019 #837
    8,877
    5,729
    I had it all set up for you ...
  18. Jun 24, 2019 #838
    Scheny
    Scheny
    Scheny
    Feb 26, 2019
    52
    13
    Vienna, Austria
    I read your book proposal and it is suggesting to use a magnetic coupling. Wow, it is working under misalignment, and has 112% efficiency, as alignment errors will recuperate into additional torque.
  19. Jun 24, 2019 #839
    5,874
    1,492
    Hmmm, I'm drawing a google blank on Hermschmitdt. Is it only available from the MIT bookshop?
  20. Jun 24, 2019 #840
    12,557
    4,583
    Couldn’t find any?
    BJC likes this.
