Raptor Composite Aircraft
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Dexacare, Mar 28, 2016.
  1. May 18, 2019 #581
    Mike Stewart
    Mike Stewart
    Mike Stewart
    Oct 11, 2010
    15
    3
    San Diego, CA
    I think I know that Berkut. If it was the one owned by Ryan at KSDM at one time, it was the loudest airplane I've ever heard in flight, including Reno.
  2. May 19, 2019 #582
    flyboy2160
    flyboy2160
    flyboy2160
    May 25, 2014
    168
    85
    california, USA
    Is that somebody who can judge if this is suitable for a DARwin award? Or do we have to wait for the smoking hole in the ground?
    pictsidhe likes this.
  3. May 19, 2019 #583
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    Calgary, Alberta, Canada
    It looks like DARs come in many different flavors and I doubt if many have any experience inspecting a turbocharged, pressurized, diesel, retractable pusher because there aren't any. This is an extremely complex Experimental. We know it won't perform as originally advertised, let's just hope it flies ok without stability, control, flutter or powerplant issues.
  4. May 20, 2019 #584
    Andy_RR
    Andy_RR
    Andy_RR
    Sep 29, 2009
    144
    67
    Melbourne, Australia
    WTAF are those wing fences about...? o_O
  5. May 20, 2019 #585
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    I believe those were intended to stop some Dutch Rolling tendency shown on the model at low speeds.
  6. May 20, 2019 #586
    8,877
    5,729
    How does the LE sweep angle of the Raptor compare to other canard aircraft? (It has a huge mass aft of the firewall.)
  7. May 20, 2019 #587
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    I've wondered about the C of G myself with that 800+ pounds aft of the firewall. Given the fact that the aircraft weighs at least 1100 pounds more than first predicted (using Wayback Machine), it's clear Peter doesn't have a good handle on weight management and that likely extends to weight distribution as well. Could need a lump of lead in the nose to correct which is the last thing this design needs.
    It's unclear how much input Mark Bettosini, (an experienced designer) has had on the design but if non-designers like us here could see the bloated weight figures coming (though maybe not to this degree), wouldn't others close to the project be talking in Peter's ear about adding all these weighty systems? Then again, as before, Peter may not act on good advice from the experienced people he's consulting with.
    I saw a comment on the latest vid asking Peter if he still thought the prototype would meet the published performance predictions. I had to laugh. Peter didn't answer that one but it should be clear to ANY pilot that it won't, given the 900-1100lbs. the design is overweight. I can only assume that many posters on YT are not pilots or very ignorant ones.
  8. May 20, 2019 #588
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    On this airplane, given the designer, they could be anything whatsoever, including a poor attempt at a coffee maker. But let's assume not...
    If you take a look at Long-EZ's, COZY's, and Velocities (which this thing most closely resembles), you'll see that on MOST of them (and the ones built to plans, except for some Velocities) there's a lower winglet below the upper winglet (google pics of LE's or COZY's to see this). The reason the lower winglet is there is to help in restricting span-wise flow near the tip. Nat Puffer determined that on COZY MKIV's, removing the lower winglets decreased the deep stall resistant rear CG limit by about 0.5" - on the COZY MKIV, the lower winglets are mandatory (as much as anything is mandatory on EAB aircraft). So with them, the rear limit is 102" - without them, it would be 101.5".
    Now, I've assisted a few folks (one on an E-Racer and one on a stretched COZY MKIV) in designing/installing blended winglets, as the Raptor has (the E-Racer was the first canard to have them, back in 2007, IIRC). A few other folks have installed blended winglets on their canard aircraft in the interim as well. I made it clear to the owners of these planes that their CG range would shift forward because they didn't have lower winglets anymore. Some folks build standard, non-blended winglets, but leave off the lower winglet for aesthetic reasons, and as mentioned, some of the Velocity models didn't have lower winglets either (as well as winglets that were in-line with the leading edge of the wing, rather than shifted aft, but that's another topic).
    I'm going to GUESS that the idea behind these <horrible looking flat-plate> lower wing fences is to mimic the effect of the lower winglets on other canard aircraft and that they're put at the start of the wing blend to put them as far outboard as possible. This type of fence was something I had suggested to the other blended winglet folks, but they didn't try it (and obviously, it would have to be tested for deep stall resistance in both modes to determine if it was effective in reducing span-wise flow).
    With respect to BJC's question regarding wing sweep, the top view of the Raptor as seen here:
    if up-to-date, shows a sweep angle that looks essentially equivalent to the Long-EZ, COZY and Velocity (the Varieze had a higher sweep angle).
    And with respect to Ross's comments, paying any attention to the comments on YT is useless - none of those folks are engineers nor have any semblance of understanding of what's going on with this aircraft. Cheerleaders, at best.
    What's the current over/under on Empty Weight of the plane? Think it's gone over 3000 lb yet, with all the additional stuff that's been thrown at it?
    rv6ejguy and BJC like this.
  9. May 20, 2019 #589
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,177
    2,704
    Douglas Flat, CA
    Not to rathole this thread, but:
    "Blended Winglet" is an Aviation Partners, Inc. trademark that they use to describe their patented technology for developing smooth lofts for the transition between the wing and one or more winglet blades. They have in the past been aggressive at protecting both their patents and trademarks from other manufacturers. I don't think that they'd bother with us little folk, but I wouldn't put it past them to find it expedient to do so at some time in the future.
    When Brad Hill and I were working out the very smooth winglet transition for our sailplane, we were pretty careful to do so in a way that steers clear of AP's intellectual territories.
    --Bob K.
  10. May 21, 2019 #590
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    Oh, what the hell. Let's go for it.
    So a search of the patent/trademark listings indicates that API got their patent for "blended winglets" in 1994 and it has since expired (in 2013, according to the USPTO web site), meaning that anyone can sell "blended winglets". As far as trademarks go, there are only two live trademarks with the word "winglet" in them, neither of which belong to API (nor have anything to do with airplanes) and the 9 dead ones didn't belong to API either.
    So bring it on - they've got no IP to protect when I use the words "BLENDED WINGLET". HAH - I'll do it again "BLENDED WINGLET" :). And I don't even sell them - I just say the words every once in a while...
    bmcj and BoKu like this.
  11. May 21, 2019 #591
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,859
    1,882
    BDU, BJC
    [​IMG]
    Andy_RR, wsimpso1 and BoKu like this.
  12. May 21, 2019 #592
    TMann
    TMann
    TMann
    Aug 16, 2011
    137
    69
    Omaha, NE
    o_O You'll poke your eye out!
    Andy_RR and BoKu like this.
  13. May 22, 2019 #593
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    Latest vid shows another failure on the main gear door actuation design so he's leaving the door off for now.
    Also showed the rad/ intercooler guide vane array in place but it's not sealed to the HXs at all so most of the air will just flow around these. Peter still doesn't understand the importance of delta P across HXs for most efficient cooling. The scoop inlet is huge, even in the closed position. I see lots of drag here. There are hundreds of hours into this variable geometry scoop now...
    Jeff and Devon are getting the last of the wing sanding close. Kudos there.
  14. May 22, 2019 #594
    canardlover
    canardlover
    canardlover
    May 3, 2012
    36
    37
    Canton, Ga USA
    I preached weight consciousness and voiced concern for well ove
    I preached the importance of weight consciousness and adamantly voiced concern over all the unnecessary garbage being thrown into the airplane , not to mention one unnecessary oversized extremely heavy passenger side door amongst many other things. Mark did as well. We were both ignored and scoffed at by someone always thinking he knew better . Early on we threw our hands in the air and left it up to the Master Designer and project manager. We sincerely tried to keep it sane to no avail. Our recommendations were always second guessed. You have no idea the second guessing I went through during my efforts in correcting the aero problems discovered with the model. The models creation was a direct result of my apprehension upon seeing the original design and incidence/decalage settings that made no sense. At this point I respond just as Schultz did in the old Hogans Heroes TV show, " I know nothing" when asked why this or why that. New Motto comes from a little cartoon penguin , "Smile and wave boys,smile and wave".Nuff said.
    Topaz, anvegger, BoKu and 1 other person like this.
  15. May 22, 2019 #595
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,859
    1,882
    BDU, BJC
  16. May 22, 2019 #596
    8,877
    5,729
    What is the current empty weight, and how much could it be reduced if redesigned?
  17. May 22, 2019 #597
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    Ugh. I feel your pain here again Jeff, and Mark's too. Thanks for posting on this, you are doing fine work on the composite side. Stay in the shade while you are finishing that sanding outside.
    Topaz, Turbine Aeronautics and BoKu like this.
  18. May 23, 2019 #598
    Mark Z
    Mark Z
    Mark Z
    Aug 29, 2012
    518
    241
    Granbury, Texas USA 0TX0
    I’ve enjoyed watching you guys work. I know it’s hard when your heart isn’t in it.
  19. May 23, 2019 #599
    canardlover
    canardlover
    canardlover
    May 3, 2012
    36
    37
    Canton, Ga USA
    Correct, it exhibited horrendous spiral instability. Wings level to 50+ degree bank angle in three rapid cycles. This occurred when arresting descent and beginning "flare " to establish normal canard approach deck angle before touchdown. First occurrence was quite a surprise.
    rv6ejguy likes this.
  20. May 23, 2019 #600
    canardlover
    canardlover
    canardlover
    May 3, 2012
    36
    37
    Canton, Ga USA
    73"]flow[/QUOTE[/QUOTE]
    Markproa likes this.
