Ranger electrically powered?!?
Discussion in 'Electric Propulsion' started by erkki67, Jul 26, 2019.
  1. Aug 23, 2019 #41
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,752
    189
    And if a boost by solar panels on the planned wing surface of the Ranger is a way to get close or over the 2h flight time, so why not!
    Fritz, what are the actual wing dimensions?
  2. Aug 23, 2019 #42
    7,323
    2,105
    40kWhr of batteries should do it.
    You'll struggle to build a battery pack under about 200kg. That will mean a higher gross weight, which will need an even larger battery. Your solar wing would knock 10% off the battery.
    It is not currently possible to build a 2hr endurance electric Ranger. This is why people who do the maths drone on about the necessity of efficient airframes... Its nonsense trying to scheme a 2 hour endurance electric ranger. Barn doors make awful electric planes.
    If you really want an electric ranger, you will have to change the airframe and target. Stretch the span out and settle for an hour, and you have something feasible.
  3. Aug 23, 2019 #43
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,550
    320
    Sydney
    It can only happen if you have a hybrid inside doing the charge for the electric systems.
    Or make it a slippery motor glider, add solar cells and be very efficient.
    Then name it Ranger
  4. Aug 23, 2019 #44
    GeneG
    GeneG
    GeneG
    Jul 6, 2019
    74
    5
    Arkansas
    I calculate 307.69 pounds using leaf batteries
  5. Aug 23, 2019 #45
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    737
    213
    Just an Ohioan
    You've invented 100% efficient solar cells???
  6. Aug 23, 2019 #46
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    828
    75
    Europe
    No I just have used the most most suitable planform using 30% efficient cells.
  7. Aug 23, 2019 #47
    7,323
    2,105
    Wasnt this thread about the ranger?
    500 square feet of wing area is the wrong ranger.
  8. Aug 23, 2019 #48
    7,323
    2,105
    Really? 24kWh and 648lb
    There is more to a battery than bare cells.
  9. Aug 23, 2019 #49
    GeneG
    GeneG
    GeneG
    Jul 6, 2019
    74
    5
    Arkansas
    I get 19.6 watts per square foot. Figure 70% of wing area max.
  10. Aug 23, 2019 #50
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    828
    75
    Europe
    Right..but I claimed a plane with 14 m span.
  11. Aug 23, 2019 #51
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    737
    213
    Just an Ohioan
    Here is what a real 14KW system looks like:
    Due to an errant golf ball and a sympathetic solar company I know those panels each cost $300. I will let you count the panels. How does that fit into your build budget? And is your hanger big enough? Will you fly on bright, mid summer days around noon time? No? Then subtract substantial amounts of energy production! I know because I watched it like a hawk to make sure my math would add up and it did. A $20,000 system after tax rebate that will never pay off!
    BTW: Our landlord put this monstrosity in 4 years ago over my protests to serve the farm of which we are renting the house. He really thought he was helping us out but zero savings since the buyback program knocked us out of the county co-op program. In fact, we just paid the most ever for electric last year in the 10 years we have been here! Its not as easy as you make it sound!
  12. Aug 23, 2019 #52
    10,195
    6,916
    “Alternative energy” is subsidized by all consumers on investor owned utility systems.
  13. Aug 23, 2019 #53
    7,323
    2,105
    Whereas fossil fuels are subsidised by your taxes.
  14. Aug 23, 2019 #54
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    828
    75
    Europe
    You are quite right..I asked the company who provided the cells for Solar Impulse a 1 m2 piece...I never even got an answer from them.
    NASA and others have access to 30 % efficient film thin panels. Just 3 m2 would provide 1 KW in extra push at optimal conditions.
  15. Aug 23, 2019 #55
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,752
    189
    So, the battery power has to be multiplied by the factor of 4 before it’s going to be interesting to have a Ranger powered by only electrons! :confused:
    Remains a GK, Harbour Freight, B/S conversion to stay aloft for at least 2 hours.
  16. Aug 23, 2019 #56
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,752
    189
    I suppose that the wing area of the Ranger is in the region of 8m2 or 81sqft so there is roughly an max additional 3kw available....
  17. Aug 23, 2019 #57
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    828
    75
    Europe
    Yes and Lazair would cruise with that power.
  18. Aug 23, 2019 #58
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    737
    213
    Just an Ohioan
    FYI, I took that pic at 1:30 this afternoon and in direct sunlight it was producing 7100 watts. When it was new 4 years ago it would have easily produced over 12KW. I saw it with my own eyes. So it shows the degradation of the cells. The cells have a 15 year or so lifespan where they will produce useful energy then are considered defunct. Will you buy new panels every 4 years to keep the energy production where it needs to be?
  19. Aug 23, 2019 #59
    12notes
    12notes
    12notes
    Aug 27, 2014
    906
    557
    Louisville, KY
    You keep repeating this lie, when the designer has stated publicly that it does not.
  20. Aug 23, 2019 #60
    10,195
    6,916
    When you accuse someone of repeating a lie, please quote them so that we do not misunderstand whom it is that you are addressing.
    Thanks,
    pictsidhe likes this.
