Ramp geometry - Landing gear design
BenoitLescot
Jan 13, 2010
80
Provence, France
Hi there,
Am working on the landing gear for my project, I was having a thought about the ramp geometry, basically I want my gear to be as low as possible for obvious weight reasons, but one specific about flying-boats is when pulling up the ramp, a picture better than 1000 words so here is what I'm worried about :
Is that likely to be a problem or are the ramps out there offer very smooth transitions ? what is the typical ramp angle ?
thanks all !
BenoitLescot
Jan 13, 2010
80
Provence, France
Good, at the moment, I can accomodate 25° which has to be more than enough.. can't imagine going up a 25° ramp anyway, which is also above the 15° tipback angle.. interesting, then I suppose flying-boats must have a few extra tipback angle degrees (i.e. wheels further aft) to be able to climb up the ramp without going on the tail..
thanks autoreply !
Kristoffon
Sep 4, 2009
348
Brazil
Pretty much every boat ramp I've seen has a rounded top, negating your concern.
It would pay off for you to survey a few ramps you might want to climb and measure both their inclination and roundedness.
BenoitLescot
Jan 13, 2010
80
Provence, France
Thanks, maybe in my next life I'll have some spare time for that ;) I'll keep a note though
Seriously, wouldn't that be part of the VFR aerodrome charts ?
5,409
Are you going to have an airplane that sits so low that it can't effectively rotate for liftoff or flare for landing?
Dan
BenoitLescot
Jan 13, 2010
80
Provence, France
why would I do that ? I was just trying to shed some light on a gray part of my knowledge of seaplanes operations, now come to think of it, floats, as in floats mounted on a seaplane not flying-boat, most definitely have a keel way lower than the keel of a flying-boat, so keel height between the wheels shouldn't be a problem for my current design
