quicksilver tail brace wires
ronr
Sep 3, 2021
6
has anyone added tail brace wires to a quicksilver? If so what difference dose it make in the flight characteristics of the plane?
challenger_II
Jul 15, 2009
1,084
Fisher County, Tx. USA
Before attempting the change, I would contact Bever, at Air-Tech, and consult with him. He is pretty much the driving force behind the Quicksilver line these days and is very knowledgeable on the airframes.
radfordc
Feb 5, 2008
1,542
I added tail brace wires to my Quicksilver 30 years ago. Don't think it made any difference in flying but seemed like a good idea.
14,218
Quicksilvers have had various combinations and geometries of tubes and wired throughout the years. Probably nothing wrong with adding some wires, but keep in mind that wires can oscillate or go slack under some loads, so make sure that wires are far enough from the prop arc to avoid becoming tangled. Also, if attached to the king post, make sure the tension labels won’t overload the post.
ronr
Sep 3, 2021
6
The ones I am looking at are supplied by air tehc.
one set goes from the top of the rudder to the ends of the elevator then to the tail skid. the other set goes from the back wing spar at the lift strut to the outside edge of the elevator. the way it is now you can move the tail up and down 5 to 6 inches and forward and back 3 to 4 inches.
Lucky Dog
Aug 4, 2021
124
I have them on my 2S and have flown many hours in a 2S without them. Forget it. Can't tell the difference and I hit the wires all the time while I'm pre-flighting.
quick582
Feb 24, 2020
16
I also have them on my GT400 and can't tell any difference with and without them. And just like lucky dog, they get in the way. I'm just too lazy to remove them.
Lucky Dog
Aug 4, 2021
124
Get the ones that run from the fin to the stabilizer, but don't bother with the ones that tie the fin to the trailing edge of the wings. Almost everyone uses the bracing wires between the fin and stabilizer. Also, Quicksilvers are very flexible airframes with or without the extra bracing wires. That flex neither alters its stability, nor detracts much from its control effectiveness. The "circle of nothing," where you can move the control stick a small amount in any direction without affecting flight - it's part of the Quicksilver experience :cool: .
