I have a Powerfin 70 inch propeller, 3 blade, "F" style blades, LEFT hand rotation. No major damage, slight wear on leading edges, perfectly airworthy as is. Ground adjustable. Well over $1000 new replacement (3 blade hub and 3 "F" blades)
I want a 4 blade propeller, RIGHT hand rotation, for use on an HKS powered Kolb Firestar. I need about 62 inch diameter ground adjustable prop for clearance from the tailboom. The engine is a 60HP 4 stroke with a 3.47 gear ratio... so I need "a lot of prop" to absorb that much torque.
Looking for Warp Drive, Ivo, Powerfin, or other high quality composite propeller.
Interested in a straight across trade if I can find someone who wants what I have and has what I want. I know, 100-to-1 shot.
