Prop pitch, rpm, and performance
Discussion in 'Firewall Forward / Props / Fuel system' started by Dana, Nov 13, 2019.
  1. Dec 9, 2019 #61
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    Using this Prop Calc, and 77F Temp:
    http://godolloairport.hu/calc/strc_eng/index.htm
    125HP at 2600 rpm. Pitched for 2500rpm:
    (2) Blade 74"x 50 = 502.51 lbs Static Thrust, needs 159.158 hp
    (3) Blade 74"x 50 = 703.51 lbs Static Thrust, needs 222.822 hp
    (4) Blade 74"x 50 = 854.26 lbs Static Thrust, needs 270.570 hp
    (2) Blade 74"x 47 = 502.51 lbs Static Thrust, needs 149.609 hp
    (3) Blade 74"x 47 = 703.51 lbs Static Thrust, needs 209.453 hp
    (4) Blade 74"x 47 = 854.26 lbs Static Thrust, needs 254.336 hp
    Ideal 74" Prop seems to be for 125 hp Pitched for 2500rpm:
    (2) Blade 74"x 39 = 502.51 lbs Static Thrust, needs 124.144 hp
    (3) Blade 74"x 28 = 703.51 lbs Static Thrust, needs 124.780 hp
    (4) Blade 74"x 23 = 854.26 lbs Static Thrust, needs 124.462 hp
    130HP at 2800 rpm. Pitched for 2700rpm:
    (2) Blade 74"x 50 = 586.12 lbs Static Thrust, needs 200.494 hp
    (3) Blade 74"x 50
    (4) Blade 74"x 50
    (2) Blade 74"x 47
    (3) Blade 74"x 47
    (4) Blade 74"x 47
    Ideal 74" Prop seems to be for 130 hp Pitched for 2700 rpm:
    (2) Blade 74"x 32 = 586.12 lbs Static Thrust, needs 128.316 hp
    (3) Blade 74"x 23 = 820.57 lbs Static Thrust, needs 129.118 hp
    (4) Blade 74"x 19 = 996.41 lbs Static Thrust, needs 129.519 hp
  2. Dec 9, 2019 #62
    Super Moderator Staff Member
    Apr 4, 2007
    8,775
    3,137
    Static thrust is meaningless when you're trying to optimize a propeller for climb at 60 knots.
  3. Dec 9, 2019 #63
    AdrianS
    AdrianS
    AdrianS
    Jul 5, 2014
    421
    268
    Australia
    But it was in colour and everything.
    mcrae0104, Topaz, Dana and 1 other person like this.
  4. Dec 9, 2019 #64
    11,913
    3,411
    High static ground thrust means you will fly through max thrust at low speeds and the prop then becomes a brake. Unless STOL competition only, you want max load at climb or cruise or somewhere in between. Before you start moving means it’s always loosing.
  5. Dec 9, 2019 #65
    3,961
    1,165
  6. Dec 10, 2019 #66
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,326
    586
    capital district NY
  7. Dec 11, 2019 #67
    Lendo
    Lendo
    Lendo
    Feb 7, 2013
    375
    67
    Brisbane
    Propeller design is an art. I look at everything I can, I managed to get a copy of Jan Carlsson's Prop program, while he was alive. I would love to know his background, as a lot of work went into this.
    However it wasn't the be all and end all as his new program was a step up with the latest Prop Theory. He only used this for his consulting work.
    I also love Paul Lipps work and spoke to him via e-mail only briefly - he felt I understood his basic philosophy and theory.
    Both men were on the right track to achieving the optimum prop design, I have developed my own theories on the subject, but that's all they are just theories.
    All I can say is best of luck with all this, the Big Boys have the Big computers and best programs money can buy.
    I say this tongue in cheek, if only the bloody things could morph in the best shape and pitch for the conditions :).
    George
    Pops likes this.
  8. Dec 11, 2019 #68
    3,961
    1,165
    Basic question:?
    85% prop....so thrust x density of air x volume of moving air = 85% of engine hp: torque x rpm?...
  9. Dec 12, 2019 #69
    10,022
    6,769
    Example of 85% efficient propeller: 100 HP out of engine into the propeller produces 85 HP out of the propeller available for propulsion. Note that aircraft speed plays a big role in prop efficiency.
  10. Dec 12, 2019 #70
    3,961
    1,165
    how is it measured
  11. Dec 12, 2019 #71
    12,480
    2,522
    85 thrust hp used by the prop. Measured in pound of force over time.
    One hp is 550 pounds per foot per second.
  12. Dec 12, 2019 #72
    10,022
    6,769
    Efficiency is output divided by input, i.e., Thrust X aircraft velocity / HP into the prop.
  13. Dec 12, 2019 #73
    4,240
    1,973
    FWIW:
    If your speed is in MPH and you want thrust in lbs, then:
    Thrust = HP x prop efficiency x 375 / airspeed
    So, if we want to know the thrust at our 67 MPH climb speed and we have a 22 HP engine, and the prop that allows it to turn at max HP RPM at 67 MPH is 65% efficient at that RPM and airspeed, then:
    22 x .65 x 375 /67 = 80lbs of thrust
    Observations:
    1) Propellers generally get more efficient at higher airspeeds (until their design speed is reached, if it is fixed pitch)
    2) Despite the above rule, thrust generally decreases with airspeed (as would be expected due to that airspeed term in the denominator of the formula above)
    proppastie likes this.
  14. Dec 12, 2019 #74
    Apr 4, 2007
    8,775
    3,137
    Power is thrust times velocity, one HP is 550 lb-ft/sec, which is lbs times ft per sec, not pounds per ft per second.
    That's thrust HP (THP), as opposed to shaft HP (SHP), which is what the engine actually produces (often called brake HP (BHP) in the automotive world).
    Prop efficiency is THP divided by SHP. Note that by definition, THP (and thus prop efficiency) equals zero if the aircraft isn't moving.
  15. Dec 12, 2019 #75
    10,022
    6,769
    Which is entirely logical, since the purpose of the propeller is to propel.
  16. Dec 12, 2019 #76
    12,480
    2,522
    Hmmm. I just know that 550 pounds lifted in one second is one hp. (/ is read as per, I thought)
    Anyway, it's interesting that the 375 (in the post 73 formula) is derived from the hp formula. (550x60=33,000 and 33,000 divided by 88fps is 375)
    So I just remember that at 375 mph, one hp is equal to one pound thrust at 100% efficiency. Can't do better than that.
  17. Dec 12, 2019 #77
    7,375
    6,318
    I just know enough to know that I would be wasting my time designing and building a prop. Local friend of mine designed and built and sold props for several years for different hp 1/2 VW engines.
  18. Dec 12, 2019 #78
    AdrianS
    AdrianS
    AdrianS
    Jul 5, 2014
    421
    268
    Australia
    All those odd magic numbers based on the length of a king's foot...
    ...would disappear if you used SI units.
    pictsidhe likes this.
  19. Dec 12, 2019 #79
    11,913
    3,411
    What is the fun in that?
  20. Dec 12, 2019 #80
    10,022
    6,769
    Anyone can calculate in SI; it takes a mastery of obtuse units to work in Btu’s, feet, inches, miles, knots, water that turns solid at 32 degrees, slugs, pounds force, inches of mercury, etc. We do, however, share time units with SI.
    akwrencher, Pops, dino and 1 other person like this.
