Press a button save the plane avionics
way_up_noth
Jan 18, 2019
79
toronto
I’m in the construction phase of my build... but you sometimes have a question
Is anyone offering the press a button save the plane like cirrus does...does dynon have that feature or other experimental avionics firms?
Toobuilder
Jan 19, 2010
5,015
Mojave, Ca
A little vague... Are you talking about the Cirrus parachute - to "save the plane" in case of structural failure, or the Garmin Autoland system to "save the plane" in case of pilot incapacitation?
What scenario are you trying to "save" the plane from?
way_up_noth
Jan 18, 2019
79
toronto
Not related to the parachute...all software and auto pilot.... The avionics levels the wings ..raises the nose..and so on
Pilot incapacitated or flying into clouds and getting disoriented
Wondering if it’s exclusive to the cirrus
13,974
I believe it’s a newer addition so market has not had time to acclimate. Generally if you can’t level the plane out, the autopilot will not either. It’s called pilot training. If you are in that situation, you have stuck your neck way too far out. Panic is what is killing you not the plane.
Toobuilder
Jan 19, 2010
5,015
Mojave, Ca
OK, the "wings level" function is available on most of the current experimental AP's. So is a "180" function.
That is a long way from a "save the plane" description though. That level of automation helps, but isn't going to fix thunderstorm penetration, airframe icing or structural failure - just a few of the common situations that a "save the plane" button would drive.
Turd Ferguson
Mar 13, 2008
5,414
Upper midwest in a house
No, the cirrus vision has a one-button autoland. If the pilot becomes incapacitated, a passenger can push the button, the plane will fly to the nearest suitable airport and land without any further input.
Hephaestus
Jun 25, 2014
1,920
YMM
The autoland is part of Garmin's new electronics suite. Will probably get integrated into multiple certified aircraft.
Probably 5years before we see it in an experimental/homebuilt panel.
A basic wings level autopilot system and synthetic vision (see the mountain approaching you're about to crash into) would save more than a few IMC lives every year.
cvairwerks
May 12, 2010
236
North Texas
A good friend led the LM team and they won the 2018 Collier Trophy for Auto GCAS... this is essentially what you are talking about, with some additional triggering points. Not a task for a single person to develop, unless you want to dedicate years to it.
way_up_noth
Jan 18, 2019
79
toronto
I’m a bit of a land lubber .. buiding and training at same time... my original post was not very helpful
Now that I know what to search for...as posted above here is a video about it... Garmin auto land
Thanks guys
