Preceptor Pup Wing Rib Dimensions
Ma77
Jan 4, 2020
11
Hi all. So my issue is I do not have enough information about the wing rib for the Pup/Super Pup/so on. My plans do have a template, but my plans are in electronic form, and I have no dimensions for proper sizing of the rib.
Would anyone have a lead on this information? Or maybe a a formed rib?
Any and all help would be appreciated.
Hawk81A
Sep 3, 2021
39
I have a plywood cut out made by tracing one of the formed ribs from my formerly owned Ultrapup. I will measure it tomorrow if you haven't come up with anything by then. Dennis
Ma77
Jan 4, 2020
11
Thank you, Sir.
No I haven't had any luck yet. I contacted the company I ordered from and I've put put in a holding pattern. I appreciate anything you can help with. This detail is what is keeping me from starting the build.
Respectfully,
Matt
Hawk81A
Sep 3, 2021
39
My apologies. Been a hectic weekend and I forgot about this. I just went out to look and I can't find it. Found part of a P-51 radiator, a KR-1 landing gear, a MK75 practice bomb, but no wing ribs. Could just be where I can't see them. I'll look more during the week
soneraifred
Jun 16, 2015
9
Franksville, WI USA
The Preceptor N3/Super Pup/Ultra Pup wing uses a Goettingen 387 airfoil. The chord is 48”. The main spar centerline is 9-1/4” from the leading edge, and the rear spar centerline is 24” aft of the main spar centerline.
Ma77
Jan 4, 2020
11
I completely understand, we all have families. Thank you, but please don't go to far out of you way. I appreciate all your help.
Matt
Ma77
Jan 4, 2020
11
Thank you! That's a lot of info
GeeZee
Feb 25, 2019
185
Indianapolis, IN
I just recently found the “fly preceptor“ forum. I joined the other day and downloaded plans to several of the variants. Just poking around the plans, I too saw that the rib drawing has no dimensions or mention of the airfoil. Looking at carlsons website for spar material I noticed they sell ribs as described by soneraifred. They are kind of pricy but buying one for a pattern might be worthwhile. The forum is not very active at all but I think some builders do monitor it so help could (theoretically) be had if needed. The plans are high quality scans and are very legible.
Ma77
Jan 4, 2020
11
Thank you. I have contacted them for a few more dimensions as well as a picture to compare to the plans. It may not mean anything ultimately, but I'd like the visual.
Ma77
Jan 4, 2020
11
I wanted to share what Carlson's Aircraft sent. All together this style would save weight. They make two styles. One for stitching and the other for riveting. The cap strips are .50 inches. They are the same basic shape and dimensions.
GeeZee
Feb 25, 2019
185
Indianapolis, IN
Thanks for sharing. Looks a lot like the Skylite/Lil Bitts ribs except they use “widgets” to connect to a round spar. So the caps are just right angles, not C sections? I didn’t see any fluting at the curved section. Maybe it just doesn’t show up in the photo. N3 pup is on the short list.
Ma77
Jan 4, 2020
11
Some new information.
I went to Staples and had them print the wing rib page to standard 24x36 inch blueprint size, and the rib is almost (if not right at 48 inches. I measured a lightening hole and a spar cutout, those too were close if not right on. This I can work with.
Now the Butt Rib is different, but I can fix that.
Thanks for everyone's help.
Ma77
Jan 4, 2020
11
Oh, before I forget. For some who are new to building and/or this post, remember to add 1/8 inch around the rib template when cutting your rib blanks.
Ma77
Jan 4, 2020
11
I thought I'd share what I have. I used a straightedge to align the bottom of the template. I believe the original drawing was drawn to a smaller dimensions then enlarged when the plans/blueprints were made. The lines of the full sized print aren't exactly straight. It's not a problem, just get it close, and make sure your lines flow when sanding the template/block to size.
Bellaire MK
Oct 11, 2021
13
The original rib was a Gottingen 387 hydroformed from .016 2024-T3. by Craig Hyatt out in Arizona. I know a guy that has a new set still in the box. 404-309-8208 ask for Wayne at Southern Aero in Georgia.
Ma77
Jan 4, 2020
11
I'm sharing a bit more for anyone who may need or be following this.
I've started on the master template. The paper template is glued down and have made a correction to the bottom of the trailing edge. Not a big deal, the outline isn't straight on the paper template. Just corrected for it before cutting/trimming.
