Practice Welding Jig
Jan 3, 2014
6,143
Wisconsin
I wrote a short article on my blog about the jig I use to practice welding.
http://cassuttairplane.com/index.ph...lding-jig-for-aircraft-fuselage-construction/
Here's the short version.
Welding is functional art. Art requires practice. At least 15 years ago, probably more, I was asked to weld a piece on a fuselage. Although very experienced I was smart enough to practice a little before welding on a fuselage. Well, I struggled. So I slapped together a jig from all the scrap I could dig up and built a jig knowing I'd throw it in the scrap pile outside after I was warmed up on thinwall.
It worked well. My passion for aviation expanded over the years and I found myself walking out back and grabbing the rusty jig from the pile so I can practice each time I weld.
I no longer weld for a living, which means I need practice every single time I touch a torch to an airframe.
The jig is designed for two things, running beads and laps on sheet and welding tube clusters. I've also practiced fillet welds, edge, etc. This jig will do it all.
Here is a drawing I made. If it's too small go to my website and open this image in a separate window. I believe all the dimensions are on it.
Looking back, I really wished I would have taken the time to really make it nice. The clamps are cut from 2" angle iron. There's a 20 gauge shim under the one block to allow the two sheets to lap.
The tube cluster side of the jig is designed to fit a 6' tube 3/3" and a 5/8" tube 4" with a saddle cut.
I practice on 4" x 4" 20 gauge steel which is .0359", close enough.
For more photos and more explanation you can visit my blog.
Again, don't do what I did and slap the jig together. I don't think I even used a tape measure. Back then I figured this was a one shot deal and I'd go about my life. Really take your time and build it right, in fact, build it better than mine. It doesn't take long to build it right.
If my lifetime association of welding and fabricating has taught me anything it would be that practice is paramount to success. I love to throw the jig on a bench and just warm up for a half hour or so, turn on some tunes and get those muscles relaxed and find your mojo. Don't use the actual airplane fuselage as your learning tool.
If you have any comments or questions please do so. In the mean time I'm headed to work.
