Position of dragwires in wing bays
David Teahay
Aug 22, 2018
46
guloid plain,Mars
Hello there����,pls take a good look at the small dots on the bays of this two-spar wing
https://scontent.flos2-1.fna.fbcdn.net/v/t1.0-9/fr/cp0/e15/q65/51665005_787232984985580_2911007715151052800_o.jpg?_nc_cat=102&efg=eyJpIjoidCJ9&_nc_eui2=AeEngFsUkF7L3MNnQRnWFkka3WtxSD9ueMVRn853VKnNrbqj1ur1Sj8Sm8fa0B_ahNxi4oDO8_IBZvLDDiP7AwAOnOEM73e9xsuS50QtNqmu4R-84ZSn942QtgpXT2cMTqY&_nc_ht=scontent.flos2-1.fna&oh=f2fcf1fb566718b723f21987a6c5edaf&oe=5CB6A576
my question is, is the drag and anti drag wire as seen in bay 1 supposed to connect to the root of the compression tube or to the intersection between the wing spars and compression tube as seen in bay 2 or,is the drag and anti drag wire supposed to connect to the wing spars as seen in bay 3.
This is the point I'm at in my project,your answer will be much appreciated.
Inorder words,which bay is set up correctly?1,2 or 3?
Chilton
Jun 28, 2014
180
Jersey, channel islands
All the ones I have seen the compression strut has a fitting on the end which has the drag wire attachments on it, in terms of your drawing the closest would be bay 2.
15,404
Because the drawings are not that detailed, you can't really make a judgment. It's mor of drawn instructions than plans without more info.
VP1
Todd C.
Oct 12, 2009
253
San Diego, CA
1.Putting nonaxial loads on a compression member is generally not the best option.
2. A good option- wires can attach to compression strut attach point. Simple/light.
3. Would work, but #2 seems simpler to me
DaleB
Jan 22, 2019
15
Omaha, NE
As noted by others, #1 is not good as it will put bending loads on a compression member. #3 will put additional bending loads on the spars.
If you really want to know which is best, build a small model. Doesn't need to be to scale. Build three identical structures with the same materials, attach wires and see how well each does when you apply a load at diagonally opposite corners. My guess is that the results would be very instructive. But I'm no engineer, I really know nothing about it.
PTAirco
Sep 20, 2003
3,648
Corona CA
In a Citabria there is no compression strut at the root at all! To pull the wings or reattach them, I attach a temporary strut and tension the wires correctly, hang the wing and then pull the strut out. Cheap but annoying.
deskpilot
Jun 30, 2009
1,131
Here's how it's done on my Thruster. Inboard bay has only a diagonal compression tube. The hanging wire goes down to the strut mounts (I think). Second bay has 2 diagonal wires mounted as per image. The 3rd bay has nothing. All bays are of the same size.
Now, I'm thinking that my plane might need a more powerful engine due to modifications making her heavy. Something like a Hirth 582 in place of the Rotax 503. In view of this, speeds might go up and beyond the design limit of the wing so will I need more compression tubes? Any advice gratefully received. Mods, make this a separate thread if you deem so.
