Pop rivets holding 1.5 mm plywood on 15x10mm spruce longerons . Good idea ?
Discussion in 'Wood Construction' started by Speedboat100, Oct 4, 2019.
  1. Nov 8, 2019 #41
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    F**k...the epoxy did not cure at all.
  2. Nov 8, 2019 #42
    narfi
    narfi
    narfi
    Feb 23, 2016
    751
    376
    Alaska
    Temperatures or mixing issues?
  3. Nov 9, 2019 #43
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    Too much hardener apparently...I had to scape it all of.
  4. Nov 9, 2019 #44
    7,131
    6,022
    IRON-- Why didn't I think of that ? Don't answer.
  5. Nov 9, 2019 #45
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    It has finally started to cure...I messed it up first. I only sacrifised one knife for this.
  6. Nov 10, 2019 #46
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    Bending the other surface.
  7. Nov 10, 2019 #47
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    650
    156
    Just an Ohioan
    Are you saying you laid the inner ply parrallel to the spar so the outer ply ran from spar top to spar bottom?
  8. Nov 10, 2019 #48
    Sep 18, 2008
    4,858
    2,070
    That's correct. I should have been more specific. That inner ply stays relatively dry and stiff while the outers are nice and limp, and so the sheet will bend around the leading edge more easily with outer grain chordwise.
    poormansairforce likes this.
  9. Nov 10, 2019 #49
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    650
    156
    Just an Ohioan
    Thats neat, I'll have to remember that. Thanks.
  10. Nov 11, 2019 at 7:57 PM #50
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    Prebending helped a lot here.
  11. Nov 12, 2019 at 2:32 AM #51
    3,797
    1,098
    Whenyou are done is it going to be a table?
  12. Nov 12, 2019 at 7:39 AM #52
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    It is like a shark fin.....a wind fairing for the tower of my wind turbine prototype.
    Wings will follow.
    proppastie likes this.
  13. Nov 12, 2019 at 7:43 AM #53
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    I realized that I can reduce the turbulence by 95% .
  14. Nov 12, 2019 at 8:41 AM #54
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    I used these to heat it.
  15. Nov 12, 2019 at 7:25 PM #55
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    Fin..will be white and blue. Doesn't it remind you of something that sorta lifts itself into the air and so forth...whuzzimhacallit ?
  16. Nov 12, 2019 at 7:34 PM #56
    3,797
    1,098
  17. Nov 12, 2019 at 7:52 PM #57
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    Link will not show...but yes....I am like building an aerodyne all the time...and it is just a wind mill.
  18. Nov 13, 2019 at 12:40 AM #58
    3,797
    1,098
    copy link from the address bar..... paste to the body of the reply
  19. Nov 13, 2019 at 5:46 AM #59
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
  20. Nov 14, 2019 at 6:16 AM #60
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    702
    55
    Europe
    I mean did not work.
