Pop rivets holding 1.5 mm plywood on 15x10mm spruce longerons . Good idea ?
Discussion in 'Wood Construction' started by Speedboat100, Oct 4, 2019.
  1. Oct 5, 2019 #21
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I change all the longerons into Black Arder. This is a non flying aerodynamical part of a bigger test model that is supposed to brake the Betz's limit in near future.
    Thank you again for all the commets.
    https://en.wikipedia.org/wiki/Betz's_law
  2. Oct 5, 2019 #22
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    Backside has now a washer....which seems to cure the cracking phenomena.
  3. Oct 5, 2019 #23
    Sep 18, 2008
    4,860
    2,072
    Staples or rivets or nails won't help much at all if the glue fails. The shear and tensile strength of the glue is far higher than any mechanical fastener in wood other than a nut and bolt, which is why standard aircraft practice with wood is to make joints by gluing in shear or by bolting. Wings and tails are attached with bolts, as are engine mounts, control surface hinges, landing gear, and so on; somtimes wood-to-wood, usually wood-to-metal.
    I did some tests on one-inch-wide 1.5mm Baltic Birch strips that I had scarfed-jointed at 15:1 and glued with epoxy. I pulled on them with a calibrated hydraulic affair and all of the strips failed at between 1100 and 1500 pound of pull, and most didn't break at the glue joint. NO mechanical fastener would have taken anywhere near that. A pop rivet or anything else would tear out instantly if the glue failed. Those fasteners wouldn't save your skin if your glue joints came apart in flight.
    1.5mm ply bends like a blanket across the outside grain if you steam it. I used a spray bottle with water and a clothes iron. Spray the water on the wood, and run the hot iron over it. The water steams and pops and sizzles and softens the outside plies. The center ply is difficult to get the steam into, so it remains rather stiff and the ply has to go on the leading edge parallel to the span. I steamed a strip of the that ply like that and spiral-wrapped it around a pencil without it cracking. MIL-spec aircraft ply is designed to take that sort of treatment.
    Then you wrap the limp leading edge ply around the leading edge and hold it there with straps. Let it dry thoroughly, then glue it down.
    Pops and Speedboat100 like this.
  4. Oct 5, 2019 #24
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,009
    1,362
    Marion, Ohio
    Then it would be time to scrap the whole thing, I think.
  5. Oct 5, 2019 #25
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    Yes Dan Thomas has it right...the pop rivets alone cannot do much. I could also use screws to fasten the campered part plywood into the wooden longeron.
  6. Oct 5, 2019 #26
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I have to try this...otherwise the whole bending affairs seems very tricky to do.
    This piece is a fairing to reduce 95% of the tower turbulence that affect the VAWT blades.
    This is very simple aerodynamics...but no one has ever tried it before in this kinda system ( makes you wonder ).
  7. Oct 6, 2019 #27
    Tony Spezio
    Tony Spezio
    Tony Spezio
    Sep 19, 2019
    30
    24
    With all my years in aviation I would say NO. Pop rivets for aluminum to aluminum yes if pop rivets are aluminum.
  8. Oct 6, 2019 #28
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I can only find one thing positive about pop rivets..they make the craft look like a metal bird with silver ( metal ) paint job. And it sorta does reinforce the part where the steam bending may have deteriorated the glue of the plywood.
    Down sides are...more weight, more complexity...more turbulent flow.
  9. Oct 6, 2019 #29
    Sep 18, 2008
    4,860
    2,072
    MIL-spec birch plywood can take boiling water for 30 minutes without glue degradation.
  10. Oct 6, 2019 #30
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    But can it take bending at the same time ?
  11. Oct 7, 2019 #31
    Sep 18, 2008
    4,860
    2,072
    That's how it's often done. Boiled in some container, or as I described, sprayed with water and the iron run over it to boil it and force it in. Then it's bent. Try bending it dry and see what happens; you'll bust it if the radius is small enough. It has to be wet and hot and soft.
    From Wiki:
    Structural aircraft-grade plywood is most commonly manufactured from African mahogany, spruce or birch veneers that are bonded together in a hot press over hardwood cores of basswood or poplar or from European Birch veneers throughout. Basswood is another type of aviation-grade plywood that is lighter and more flexible than mahogany and birch plywood but has slightly less structural strength. Aviation-grade plywood is manufactured to a number of specifications including those outlined since 1931 in the Germanischer Lloyd Rules for Surveying and Testing of Plywood for Aircraft and MIL-P-6070, the latter of which calls for shear testing after immersion in boiling water for three hours to verify the adhesive qualities between the plies and meets specifications.
    See that? I was wrong. It's not 30 minutes; it's three hours in boiling water that the glues have to withstand.
    wsimpso1 likes this.
  12. Oct 17, 2019 #32
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    Pop rivets seem to do the trick that nuts and bolts would take a lifetime to install.
  13. Oct 17, 2019 #33
    narfi
    narfi
    narfi
    Feb 23, 2016
    759
    380
    Alaska
    If you are just tabbing wood feet, why not use epoxy and glass tape? It would look a lot cleaner and your brackets wouldn't rust.
  14. Oct 18, 2019 #34
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I found this way much faster.
    narfi likes this.
  15. Oct 18, 2019 #35
    narfi
    narfi
    narfi
    Feb 23, 2016
    759
    380
    Alaska
    Fair enough :)
  16. Oct 18, 2019 #36
    wktaylor
    wktaylor
    wktaylor
    Sep 5, 2003
    121
    66
    Midwest USA
    Wood is very susceptible to moisture intrusion... and is also sensitive to the installed fastener material/finish. The small brass nails used in construction have relatively small cross-sections and are naturally corrosion resistant.
    Why not use high quality glue and temporary fasteners, such as clothes-pins or wood-worker's clamps [that look like clothes pins] for lap-joint clamp-up during Adhesive cure?
  17. Oct 18, 2019 #37
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I just simply needed more strength to this.
  18. Nov 6, 2019 #38
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I think I will try the pop riveting tomorrow on this.
  19. Nov 7, 2019 #39
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    I almost blew it.
    Actually the pre drilled holes and pop rivets saved the operation. Not like I planned, but still.
  20. Nov 7, 2019 #40
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    709
    55
    Europe
    In pricipal I am very happy how this turned out.
