Pilot and Static Lines
HomeBuilt101
Oct 20, 2015
289
Aguila AZ
radfordc
Feb 5, 2008
1,368
The rigid nylon tube will bend into a tight radius if you use a hot air heat gun to warm it first.
9,200
Pitot pressure is so low any kind of tubing will work. Vinyl tubing may be too soft to push into the fittings, polyurethane will work well.
7,426
Smaller ones? 1/4" seems a bit overkill. Pneumatic tubing would be my choice, maybe with some heat for tight bends. I've only played with pneumatics the metric side of the pond...
Stuff like this, notice the bend radius it will do: Festo tubing
gtae07
Dec 13, 2012
1,960
Savannah, Georgia
It's pretty standard because the push-to-connect fittings are common and it's easy to get, and to a point the larger tube will be a little more resistant to getting clogged with moisture. Of course, you still want to route your lines properly to avoid moisture traps.
I'm using this stuff: https://www.mcmaster.com/#catalog/123/141/=19tk0cp
It comes in multiple colors so you can easily tell which is which. I went blue for airspeed, green for AOA, and yellow for static.
