PC-60 conversion
6,961
15,839
I didn’t know the RR-O-200 was different from the regular. I thought it was just a licensed copy. PC is more a RR version. Interesting
6,961
Its an interesting project from an historical perspective, but 178 lbs for somewhere between 57 and 70hp is a lot of weight.
15,839
Weight wise equal to a C-90. I also think the prop used might be a little aggressive. Technically the prop numbers are a good start but to get the ground clearance it’s just too much a change diameter to pitch. A 72x48 like it should have would probably make it climb like a rocket. That or ease up on the pitch with the same diameter. I bet it’s close if propped right.
The problem is cost and parts. When you could go to a surplus seller and get one for $200, made it palatable. Now, if one unique part breaks, it might be years until you find another.
I would be game for a cheap good one. My thing has a 290 GPU, but it is very much a clean conversion. It would be hard to make it work if you had to chase parts.
