Paul Weston Sea-Era
Q
qxev
Guest
Identical? No. On is a delta and one is a delta with a square wing placed behind the AC that pivots. As for WIG? You be the judge.
Holden
wide wing over water
Rohr 2-175
Early in the program somebody realized that the plane was capable of floating on its sealed, foam-filled wing. Tests with scale models showed that the airplane could take-off and land on water with the help of hydro-skis. This opened up the possibility of snow landings as well. With retractable skis, the Two-l75 would certainly have had the cleanest seaplane configuration ever seen.
it seems to me interestingly
Holden
Banned
Jan 18, 2003
1,319
USA
qxev,
Have them email me and we can get a design that would work for the USA and Russian markets and make some money. Must be roadable, though... Can anybody speak English or German?
Holden
Q
qxev
Guest
qxev,
Holden
I am ready to help in this case
all information which can be useful
certainly, it should be transportable on the highway...
and house storage in the container...
http://www.ionaircraft.com/
Equipment by easily demountable wings should be feature. should be stored in the closed trailer that allows to save hundreds dollars on collecting the airport storages,
Q
qxev
Guest
Maximum take-off weight of 700 kg
Maximum pay load of 210 kg
Cruiser speed of 250 km/h
Maximum speed of horizontal flight of 300 km/h
Length of running start of 100 m
Rotax engines of 912ULS 2x100 hp.
Fuel consumption of 18 l/h
Range of reracing 2200 km
Reserved fuels of 200 l
The area covered 10 sq.m
Number of places 1 + 2
Q
qxev
Guest
the device was created by a modular principle when (центроплана, consoles, plumage, floats, a cabin, the power plant) it was possible to change a relative positioning of units in certain limits with the minimum constructive completions. Besides, loadings from all units became isolated on a power caisson центроплана (box) that allowed to create very easy and rigid design. Was decided to refuse from поддува as it reduced draft of the screw which and so catastrophically didn't suffice for running start. Therefore the MT-9 engine in capacity of 36 h.p. with a reducer and pushing screw in diameter placed from above центроплана. The take-off mass of the device made 280 kg, the area covered - 12 sq.m.
The device showed good stability and controllability on modes as near the screen (10-20 cm from water), and far from it (to 10 m). When flying by a snake the angle of heel reached to 150, speed of flight - 110 km/h. V.G.Nosov who in the specialty was the aviation engineer, instead of the test pilot flied on экраноплане. During tests it became clear that to each height there is a range of speeds and angles of attack of steady movement. If speed of flight is small, the device didn't hold height, making dlinnoperiodichesky fluctuations at the screen, thus the dynamic airbag didn't allow ELA-13M to concern a water surface.
Q
qxev
Guest
Updating R-02
Scope of a wing, m 10.00
Length of the plane, m 6.39
Height of the plane, m 1.40
The area covered, sq.m 12.44
Weight, kg
empty plane
normal take-off 560
PD Rotax 912 A3 engine 1 type
Capacity, h.p. 1 x 79
Maximum speed, km/h 165
Cruiser speed, km/h 120-160
Reracing range, km 850
Practical range, km 500
Practical ceiling, m 3000
Crew, person 2
Useful loading: to 90 kg of cargo
Holden
Banned
Jan 18, 2003
1,319
USA
qxev,
What relation do you have to this airplane? Who makes it. Looks cool
The numbers...comments if you will:
1) 700 kg x 2.2 = 1540 lbs
2) 210 kg x 2.2 =462 lbs
3) Cruise 250 x .62 = 155 mph
4) Max 300 x .62 = 186 mph
5) 2 rotax 912 = 18l x 2 = 36l/hr /3.785 = 9.5
What is the purpose of the design? Playing in water? Going places? Looks nice.
The leading edge is what most people would think is good. We tried such a leading edge and the drag was much higher on the model than flat and sharp. The top surface of a delta should be small radius (not sharp for safety). Notice what the F-22 does on the forward cockpit. This design looks nice but may not do all that the skin area can do to aid lift and lower drag. This design suffers from high drag, just like our first Sea-Era High wing model did.
The side by side twin as shown lead to very high drag and is hard to fly when the engine quits. I discuss it above in roadable must have.
Why the wing bend?
How much did it cost? Do you think it has a future? (My answer is no) Width is not going to work on roadable and garage.
You can see up but not down well. Put the canopy on the bottom...for looking at fish in the water.
my 2 cents:
Holden
Holden
Banned
Jan 18, 2003
1,319
USA
Updating R-02
Weight, kg
empty plane
normal take-off 560
Crew, person 2
qxev,
I can see how this would do WIG. The hull would catch and not glance off the water, however. Sea-Era uses flat sections and does not get the strong negative pitching moments that this hull would create. The air going around the lower nose will suck the nose down giving a negative Cm, whereas the flat panels of the Sea-Era give lift and a POSITIVE cm about the AC of the delta. The delta cm cancels out to some degree the cm of the wing, depending on size ratios, lowering trim drag allowing for high speeds.
What is the mission of this airplane? How is it useful other than water landings?
Holden
Q
qxev
Guest
qxev,
Holden
I carefully collect, and I analyze information on any new plane
Who makes it.
it is work of other group... the plane never flied. the model is made only
now the project is frozen
their producer was shot
http://wn.com/blended_wing_body
+ the plane which has chassis on the air chamber....,
it is exaggerated at a landing...., it is cleaned in flight (the rubber covering is stretched from inflating),
Why the wing bend?
attempt to use effect "a circular wing of a kaster"
http://www.youtube.com/watch?v=6XQ-C8Jv8v0
it is too much high technologies... new materials for the chassis are necessary (durability and elasticity) process of operational development will be long and painful
the price of $150 000 for the plane is mentioned.
http://www.aviaport.ru/directory/aviation/chirok/
Q
qxev
Guest
landings Speed: 35 knots | 40 miles / h | 65 kilometers per hour
Cruise: 81 knots | 93 miles / h | 150 kilometers per hour
AEVVP: 113 knots | 130 miles / h | 210 kilometers per hour
VPP, on 50 foots (15 m) an obstacle: 490 foots | 150 mposadochny distance over 50 foots (15 m) obstacle: 490 foots | 150 m Max. take-off weight: 300 kg | 661 pounds Empty weight: 205 kg | 452 funtovdvigatel: 50 h.p. Fuel consumption: 12 l /
. revolutionary design.
. new category of the planes combining qualities of the scheme «a bearing fuselage (FFA)», «a flying wing (FBA)»
landing speed of 65 kilometers per hour
question - why?
because carrying power create not only wings, but also a fuselage (the bearing case)
Flight of the "Archon SF1" Aircraft. - YouTube
Q
qxev
Guest
smooth and safe landing
planning from height on landing, the pilot feels that дископлан as though sits down on "pillow" and was automatically stabilized in cross-section section and longitudinal the directions. After that the device can already fly without intervention of the pilot to management. Also it is impossible to force to accelerate a glider landing while speed of flight, naturally, it will not be extinguished, and the effect of "pillow" won't disappear. After that "Diskoplan" will land independently - on three points of support. It is important, because even possible mistakes of the pilot at the moment of landing won't lead to unpleasant consequences.
Q
qxev
Guest
airplane-amphibian VVA-14 it was executed according to the high-plan scheme with strongly developed bearing central wing of small lengthening,
At tests of amphibian VVA-14 (14М1П) it was established that the effect of a dynamic airbag was shown at heights big, than the theory predicted. At an average aerodynamic chord of 10,75 m this effect was felt from height of 10-12 m, and at height of alignment of 8 m the airbag was already so dense and steady that pilot Yu.Kupriyanov repeatedly asked the management to allow to throw the management handle that the car sat down independently.
Bartini VVA-14 - YouTube
