Options for Suzuki G13--Complete FWF and less robust assitance
Discussion in 'GEO / Suzuki' started by Vigilant1, Mar 2, 2018.
  1. Jan 6, 2020 #21
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,655
    4,054
    Australian
    Millions of them screaming (and I mean millions, and I mean screaming) around China no problem. They are available all over the world except America.
    I don't fall for the "complexity" line, engines in cars today are just fantastically reliable, far, far more so than the "simple" engines of past decades. No manufacturer has VVT issues in terms of actual mechanical failure.
    200,000 ~ 300,000 miles is nothing for an engine these days.
    But still, interesting to see the mindsets, clearly myth and lore are absolutely deciding factors, and the reason I was looking at carburetor suppliers this morning ...
    mullacharjak likes this.
  2. Jan 6, 2020 #22
    4,240
    1,973
    As you know, perception can be pretty important in selling a product. As is often said: "if you are explaining, you are losing.'
    People buy new niche airplane engines that have a very small installed base and depend on one small manufacturer for parts. Rationally, buying an airplane engine based on the K-series is a lot less risky than that from a long-term supportability perspective. There are tons of parts and the world is a pretty small place these days. But the price/value would have to be right.
    cheapracer likes this.
  3. Jan 6, 2020 #23
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,655
    4,054
    Australian
    I like that line.
  4. Jan 6, 2020 #24
    aeromomentum
    aeromomentum
    aeromomentum
    Jan 28, 2014
    63
    94
    Stuart, FL USA
    The Suzuki K series engines are great and I have worked with one in my shop. Better for an economy car than the G series. But the G series are lighter, shorter stroke, better geometry, simpler, rev better and can be made to safely produce more power so are much better for use in aircraft. We actually looked at the K series before the G series, visited the factory where they were being produced and are able to get them factory direct at a lower cost than the G series. http://aeromomentum.com/reason.html
    The reasons for the price difference between the upright and low profile are not only the oil pan, oil pick up, dip stick and intake system but also the mounting ears. Many of these parts are CNC'ed from billet and while not individually that expensive it all adds up. A few of these parts start out as fairly large chunks of aluminum. The mounting ears are Lycoming standard so if the aircraft has a Lycoming standard engine mount our low profile engine will bolt to it and keep the prop on the same center-line.
    We have a few mounted to various Sonex models and at least one is flying.
    Like the AirTrikes drawings and picture it is absolutely possible to use the Suzuki G series upright in a tractor. We have a few customers that have done this. The distance from the prop center-line to top of the engine is the same or less than on a competitor's Honda based engine even though they use a 3 gear larger offset gearbox. So our lower cost upright engines are absolutely viable in a tractor aircraft.
    On some designs our low profile versions can save weight and money since our mounting ears are at the very back and you may not need much or any engine mount. If the firewall is sufficiently strong at the correct points you can just bolt the engine directly to the firewall (with the rubber bushings) saving the weight and cost of the engine mount.
    103, dragon2knight, Vigilant1 and 2 others like this.
