O-360 won't idle.
Discussion in 'Firewall Forward / Props / Fuel system' started by bifft, Feb 19, 2017.
  1. Feb 28, 2017 #21
    Winginit
    Winginit
    Winginit
    Jun 13, 2016
    811
    242
    x
    Can you install an O2 sensor and read what the actual fuel ratios are at different rpms? It really shouldn't be that difficult to get reasonable fuel ratios and decent performance. I have to wonder if you don't have an air leak if you can't get it to perform correctly. The manufacturer of the injection has not provided any help ? The thing to do is to start from scratch and systematically verify everything from fuel press at all rpms to timing at all rpms. You might try holding it at the rpm where it misses and use a spray bottle to enrichen the air entering the throttle body with a little fuel. If it dies, it's too rich and if it gets to run better it's too lean. Obviously you want to be outdoors to do this, no propellor, and don't stand directly in front of the throttle body in case it backfires. Then there are all the personal protection devices and a convenient water hose nearby....And proceeding at your own risk. Usually it's done to get an engine to start, but it can also be done just to Guage the effect additional fuel has on an engine. Like any time you are using gasoline, you also have to use a little common sense.
  2. Mar 19, 2017 #22
    bifft
    bifft
    bifft
    Apr 17, 2011
    245
    90
    Utah
    Thanks for all the help. Due to work and family commitments I wasn't able to get back out to the airport until today. Needed just a little bit more tweaking of the mixture arm position. Helped to go back over the installation instructions again as well. Now runs great from idle to 2200, which is all the static RPM I could get. Can't use full rich and full throttle, but the density altitude was around 7000, so should need to be much leaner than full rich.
    Took a victory lap/first taxi test around the hangars. Feels like I'm almost there.
    delta likes this.
  3. Mar 20, 2017 #23
    3,961
    1,165
    fixed pitch????? My Hartzel controllable pitch gets 2650 static, note: fixed pitch would be consistent with your RPM
  4. Mar 20, 2017 #24
    bifft
    bifft
    bifft
    Apr 17, 2011
    245
    90
    Utah
    Yes, Cato 3-blade fixed pitch. About the static RPM I expected.
